shtbxr22 Posted August 2, 2011 Share Posted August 2, 2011 I just found a patch to add launch control to my cars map. Has anyone patched a map before? any tips/help? how well does it work? Link to comment Share on other sites More sharing options...
lil_z_33 Posted August 3, 2011 Share Posted August 3, 2011 Thefranz has done it Link to comment Share on other sites More sharing options...
f1anatic Posted August 3, 2011 Share Posted August 3, 2011 Let us know when your transmission breaks down. Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 3, 2011 Author Share Posted August 3, 2011 Thanks for the useless post f1. Not bad....50/50 Link to comment Share on other sites More sharing options...
cholmes1 Posted August 3, 2011 Share Posted August 3, 2011 There is actually a whole thread on this in the transmission section. Cobb made an announcement thread that has a ton of information. Best, C.H. Link to comment Share on other sites More sharing options...
lil_z_33 Posted August 3, 2011 Share Posted August 3, 2011 i think he is referring to an opensource patch... Link to comment Share on other sites More sharing options...
sjwelna Posted August 3, 2011 Share Posted August 3, 2011 Planning on doing a lot of drag racing? -Steve Link to comment Share on other sites More sharing options...
GTTuner Posted August 3, 2011 Share Posted August 3, 2011 I have yet to see one in action. If you do this I'd like to see how it works. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 3, 2011 Share Posted August 3, 2011 ba-ba-ba-ba-ba-ba-BOOM! Link to comment Share on other sites More sharing options...
sjwelna Posted August 3, 2011 Share Posted August 3, 2011 I have yet to see one in action. If you do this I'd like to see how it works. Usually it's just a second stage rev limiter that holds rpm while not in motion to a set launch rpm (usually user defined, say 4500 rpm). I had this on my dsm through DSMLink and it also had an antilag feature to spool the turbo up at the line. (aka building 5-10 psi sitting at the line waiting for the lights to drop) Unless you're building a drag car I would highly recommend against it, recipe for some grenaded transmissions. -Steve Link to comment Share on other sites More sharing options...
GTTuner Posted August 3, 2011 Share Posted August 3, 2011 Damn glass gears. If I had a six speed swap I might try it. Link to comment Share on other sites More sharing options...
lil_z_33 Posted August 3, 2011 Share Posted August 3, 2011 i have a few friends that have these...not on legacys...they use them exclusively at the track, cars are daily driven except in winter months...not a recipe for a grenaded tranny, however, it does put more wear n tear on it... Link to comment Share on other sites More sharing options...
spec.B Dream Posted August 3, 2011 Share Posted August 3, 2011 The OP does have the 6 spd. I'm interested in the LC patch, but I haven't found one freely available to test. If anyone would like to share an opensource LC patch for testing on an '08 spec.B, PM me. Link to comment Share on other sites More sharing options...
Legend Posted August 3, 2011 Share Posted August 3, 2011 The OS patch works great but I did not like LC or FFS so I eventually removed the patch. You wouldn't want to use it anywhere but the dragstrip and I had slower 60's with it than without. I think if I had enough runs and enough tolerance for broken parts I could have improved on my launches, but in the end not worth the time/cost to try to shave my usual 1.8s launches to 1.7s launches. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 3, 2011 Author Share Posted August 3, 2011 There is actually a whole thread on this in the transmission section. Cobb made an announcement thread that has a ton of information. Best, C.H. Thanks, but I have no interest in using an access port. I am opensource tuned, however I will check this stuff out as there may be something worthwhile. i think he is referring to an opensource patch... yes Planning on doing a lot of drag racing? -Steve yes I have yet to see one in action. If you do this I'd like to see how it works. okie dokie ba-ba-ba-ba-ba-ba-BOOM! pay to play......another useless post. expected Usually it's just a second stage rev limiter that holds rpm while not in motion to a set launch rpm (usually user defined, say 4500 rpm). I had this on my dsm through DSMLink and it also had an antilag feature to spool the turbo up at the line. (aka building 5-10 psi sitting at the line waiting for the lights to drop) Unless you're building a drag car I would highly recommend against it, recipe for some grenaded transmissions. -Steve It's my daily, and will see some drag use. hopefully the 6 speed will be the insurance I need. Damn glass gears. If I had a six speed swap I might try it. i have a few friends that have these...not on legacys...they use them exclusively at the track, cars are daily driven except in winter months...not a recipe for a grenaded tranny, however, it does put more wear n tear on it... Noted The OP does have the 6 spd. I'm interested in the LC patch, but I haven't found one freely available to test. If anyone would like to share an opensource LC patch for testing on an '08 spec.B, PM me. If I get it done, I wouldn't be against letting you try it. The OS patch works great but I did not like LC or FFS so I eventually removed the patch. You wouldn't want to use it anywhere but the dragstrip and I had slower 60's with it than without. I think if I had enough runs and enough tolerance for broken parts I could have improved on my launches, but in the end not worth the time/cost to try to shave my usual 1.8s launches to 1.7s launches. Interesting. Link to comment Share on other sites More sharing options...
SSpeed Posted August 3, 2011 Share Posted August 3, 2011 I loved the old "stutterbox" in DSMLink, but the only place I ever used it was the dragstrip.... Overall, if you don't use it much your transmission may be fine (coming from someone who had to rent a Cavalier for a couple days when I blew out the center diff at the track in my daily driver)... Keep in mind that transmissions handle lots of load better than they handle lots of shock, that's how some people get away with 400+hp on their transmission while others blow up on stage 2. If you use it, slip the clutch quickly vs dumping it abruptly, and set the launch control high enough that you get slight wheelspin off the line. It's a fine line, but the former will put the shock more on your clutch than the trans, hopefully you have an upgraded clutch? If not, I wouldn't even consider the launch control. EDIT: Duh, just re-read, you weren't asking specifically about launch control, rather just about patching a map... Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 3, 2011 Author Share Posted August 3, 2011 Yessir. the first track runs, I had a blown ringland. second track runs, I killed my clutch. now everything is situated, and the clutch is good to go. I want to try launch control just to see how the car does with it at the track. it definitely won't be used on the street. Link to comment Share on other sites More sharing options...
Legend Posted August 4, 2011 Share Posted August 4, 2011 Yessir. the first track runs, I had a blown ringland. second track runs, I killed my clutch. now everything is situated, and the clutch is good to go. I want to try launch control just to see how the car does with it at the track. it definitely won't be used on the street. In for results, OP. If you have the patience, log your launches, play with your tire pressures, and take notes, I'm sure that it is possible to get better 60's with LC than without. Not a lot of gain, mind you, but it is there to be had for somebody with enough patience and track time. I just wasn't that guy. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 4, 2011 Author Share Posted August 4, 2011 Oh, and the hta68/850's will be added to the mix too. Lol Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 4, 2011 Author Share Posted August 4, 2011 In for results, OP. If you have the patience, log your launches, play with your tire pressures, and take notes, I'm sure that it is possible to get better 60's with LC than without. Not a lot of gain, mind you, but it is there to be had for somebody with enough patience and track time. I just wasn't that guy. I need to figure out my logging issues for that. 1 out of 5 of my WOT logs are usable. Most have huge chunks of info that just disappear. I've heard that logging with a 1.3 Tactrix or vag-com cable remedies this. Any experience? Link to comment Share on other sites More sharing options...
Legend Posted August 4, 2011 Share Posted August 4, 2011 Oh my 850's?? But everyone on the internets say you must run ID1000's and 850's are terrible. I run 850's and BNR68. Good recipe. And I use the Tactrix 1.3. No issues for 4 years. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 4, 2011 Author Share Posted August 4, 2011 maybe i'll have to acquire a 1.3 then. Link to comment Share on other sites More sharing options...
Th3Franz Posted August 4, 2011 Share Posted August 4, 2011 Follow their instructions. Set the LC offset to 3500 RPM first (remember the offset is subtracted from your red line). I recommend using it more as a 2-step (light throttle) to just hold the revs before you quickly and smoothly give the clutch just a little bit of slip. Also, don't sit there bouncing off the limiter. Your EGT's skyrocket and the car wants to heatsoak during LC, so at most hold it for a few seconds as the lights drop. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 4, 2011 Author Share Posted August 4, 2011 Thank you much Link to comment Share on other sites More sharing options...
lil_z_33 Posted August 5, 2011 Share Posted August 5, 2011 OP. Where did u find the patch? Please post link Link to comment Share on other sites More sharing options...
