ALX2987 Posted November 7, 2009 Share Posted November 7, 2009 I am seriously looking into buying an 05-08 legacy gt. I love how they look, perform, all that. I do however have a question about what is wrong with them. I understand that vehicle maintenance and how hard you drive your car will obviously effect if anything breaks, but there has to be some things that are bound to go wrong with most LGT's. For example, I currently drive a 6th gen. accord. (98-02) No matter how well you take care of it, and dont beat on it, about 80% of the transmissions on these cars blow, its just the way it is. When i was looking into Sentra SE-R's. There was a very common problem with a bolt coming lose in the motor and blowing it. Every car ive looked into has had one or two very common, almost stereotypical problems. Im pretty set on the LGT, but i was just wondering what problems like this i can look forward to. Thanks for any help. Link to comment Share on other sites More sharing options...
king_j Posted November 7, 2009 Share Posted November 7, 2009 some people have problems with the turbo failing at 50-60k miles. others have had no issues and have 100k miles. besides the turbo issue, i dont think there are other major problems with the car. i just purchased a 05 gt manual. for what the car is, i love it. if the turbo goes bad ill just pick up another one from the classifieds. there are other minor problems such as the famous dash rattle. if you search there is a fix for this. Link to comment Share on other sites More sharing options...
JohnnyGT08 Posted November 7, 2009 Share Posted November 7, 2009 I have an 08 with 51k miles. So far, I have had zero major issues. I have an Auto, so if you plan on modding, plan on spending some money to beef it up, it can't handle much. My biggest gripe is the stereo. It can be replaced with an aftermarket unit, but it's difficult and expensive. Other than that, it's been the best car I've ever owned and so far (knock on wood!) trouble free. FWIW, I drive my car fairly hard (see avatar ), but I maintain it well. NEVER ARGUE WITH A STUPID PERSON. THEY WILL DRAG YOU DOWN TO THEIR LEVEL, THEN BEAT YOU WITH EXPERIENCE. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted November 7, 2009 Mega Users Share Posted November 7, 2009 Turbo failure is probably the most expensive common problem. A blown turbo can deteriorate and enter the intake and therefore the engine. The wheel bearings are known to go bad and SOA has a 100k extended warranty on those. It seems like you're just wondering about motor and transmission problems which Subarus for the most part tend to outlast the other parts on the car. Keep your oil changes to around 3000, follow the maintenance schedule and you will avoid 99% of the problems out there. Link to comment Share on other sites More sharing options...
ehsnils Posted November 7, 2009 Share Posted November 7, 2009 As for the NA models. - Not much failure rate there. Not as fun, but that comes with the reliability. Link to comment Share on other sites More sharing options...
katalyst Posted November 7, 2009 Share Posted November 7, 2009 was it the pre-07 GTs that had the banjo bolt filter problem? or did that apply to all model years? interior squeaks and rattles are a pretty common complaint on the forums, seems to affect all models 2.5i, GT and even the 3.0 N/A it's not major and it can be fixed but it's somewhat annoying edit: the 08, 09 models originally had the issue with the piston ringland failures IIRC, but subaru put a stop sale on those so hopefully there aren't any out there that you would come across used, or hopefully they have been repaired Link to comment Share on other sites More sharing options...
ALX2987 Posted November 7, 2009 Author Share Posted November 7, 2009 Thanks, so it sounds like the turbo is the one thing that tends to blow. I guess if something has to go thats not too bad, because it then justifies going bigger haha. Squeaks i can live with, and i have heard before that the radio is terrible, but that can also solved somewhat easily. I am definitely going to a get a manual, how much wheel hp can these hold? How much hp can the motor safely take? Link to comment Share on other sites More sharing options...
krzyss Posted November 8, 2009 Share Posted November 8, 2009 Turbo going to la-la land may take an engine with it so it may be expensive. Krzys Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 8, 2009 Share Posted November 8, 2009 '05 LGT 5spd, bought new, modified to the hilt, never had a mechanical problem what so ever, at 107k miles and still running well. My advice, don’t start modifying, otherwise you will be unable to stop! :o) Link to comment Share on other sites More sharing options...
issai Posted November 8, 2009 Share Posted November 8, 2009 Here's a list of just a few problems I've seen reported here: - Banjo bolt - Failing turbo - OEM (stock) up-pipe catalytic converter disintegration - Bad oil pickup tube - Terribly weak paint - Injectors - Dicey automatic (IPT VB upgrade recommended) - Stereo having a mind of its own with volume or channel selection - Incorrect ambient temp readings - Climate control having a mind of its own - Squeaky, rattling dash (along with other rattling interior pieces) - Mushy brake pedal feel and questionable OEM brakes - Crappy OEM tires ... and the grand finale: - Bad synthetic oil - Soap in intercooler Link to comment Share on other sites More sharing options...
Mad1 Posted November 8, 2009 Share Posted November 8, 2009 I presume soap in intercooler implies that washing should be done carefully and by hand. Link to comment Share on other sites More sharing options...
katalyst Posted November 8, 2009 Share Posted November 8, 2009 ^ haha, the last two are running jokes on the forum; don't worry about it too much in reality. but we always poke fun at it. i almost forgot to the mention the rear wheel bearings in the 05/06 model years, but those should have been fixed by now by the previous owner, i would hope. but issai's list pretty much sums it all up edit: if you're looking at slightly older used models, the lower control arm and steering bushings may be pretty worn and require replacing, just take a look at those areas before buying Link to comment Share on other sites More sharing options...
ALX2987 Posted November 8, 2009 Author Share Posted November 8, 2009 Thanks alot, i will most likely be getting an 05-06, 1. because i like the slimmer body on them, and 2. they are less expensive. So hopefully i can find one with reletivley low miles on it and in good, shape, ill keep all this info in mind when im looking, keep the good info coming! Link to comment Share on other sites More sharing options...
Gire Posted November 8, 2009 Share Posted November 8, 2009 As we are 4-5 years in to the 05's now, there are a lot of clutches finally giving up. But thats a wear and tear item like brakes. And most of us had modified out engines to produce more power. The 2005 Clutch design system was designed with stock power levels in mind. Also these cars put out a lot more torque than a Honda, so all that torque will put stresses on these cars that aren't normally common on Hondas. Link to comment Share on other sites More sharing options...
Pataker Posted November 8, 2009 Share Posted November 8, 2009 I have an '05 LGT with 67K miles and minor mods. I havent had any major issues.. biggest thing i would say is brakes... alot of people burning through them(either driving to fast ... or warping them)... I have put my second set of rotors and third set of pads on. Great car, love it!!! Link to comment Share on other sites More sharing options...
katalyst Posted November 9, 2009 Share Posted November 9, 2009 2007+ sedans have the fold down rear seats which is a really nice option to expand the cargo area Link to comment Share on other sites More sharing options...
JMIL Posted December 11, 2009 Share Posted December 11, 2009 I'm about to pick up an 05 LGT wagon with ~100k miles. Is there any way to know if the turbo is near death? Is there any way to protect the engine if the turbo does start to fail? Thanks guys... Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted December 11, 2009 Mega Users Share Posted December 11, 2009 Nope. The only signs would be noise, a loss of power, and combusting oil. At that point it's too late. Turbos don't "start" to fail either. Most of the time it's pretty catastrophic. If the turbo does fail....STOP. That's the best way to protect your engine. GL with your new whip Link to comment Share on other sites More sharing options...
94sportsedan Posted December 11, 2009 Share Posted December 11, 2009 As we are 4-5 years in to the 05's now, there are a lot of clutches finally giving up. But thats a wear and tear item like brakes. And most of us had modified out engines to produce more power. The 2005 Clutch design system was designed with stock power levels in mind. Also these cars put out a lot more torque than a Honda, so all that torque will put stresses on these cars that aren't normally common on Hondas. Moreso the weak TOB, which is a while your in there minds well replace the clutch. Link to comment Share on other sites More sharing options...
