Adding Mesh to Stock Grill Without Bondo and Chopping Up Your Stock Grill
So I saw this http://legacygt.com/forums/showthread.php/easy-diy-additional-front-grills-and-intercooler-shield-61843.html
And wanted to do the lowers but I didn't feel like having to chop up my stock grill to make it match and didn't have the cash for an already made grill so...
A trip to Home Depot for some mesh and I used Plasti-Dip to paint as I had already Plasti-Dipped the stock grill and wanted it to match.
After removing the grill I cut a piece about 28" x 8"
http://i.imgur.com/bXU7Kh.jpg
Then I started wrapping the mesh around like so. It is necessary to cut in the middle for the hood latch.
http://i.imgur.com/wzKnjh.jpg
I drilled 4 holes on each side where indicated. 3/16" so the zip ties could be inserted.
http://i.imgur.com/OZyFX.jpg
Inserting the zip ties like so.
http://i.imgur.com/HIpeLh.jpg
Both sides complete.
http://i.imgur.com/qAGS7h.jpg
Not pretty from the back side.
http://i.imgur.com/Uqx8mh.jpg
But from the front...
http://i.imgur.com/zTYQZh.jpg
And on the car. Still have to do the lowers but that's another night.
http://i.imgur.com/XxwMQ.jpg
  • 4 weeks later...
Did you have to drill holes to attach the lower mesh?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT
Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon
http://i.imgur.com/gIooV.jpg
Yellow arrows indicate where I drilled holes for zip ties. Originally I drilled two holes for each zip tie, but you really only need one.
http://i.imgur.com/i9KJo.jpg
http://i.imgur.com/FxGMC.jpg
http://i.imgur.com/udEV2.jpg
Pretty much invisible unless you are making out with it.
Then for the top I used 4 self tapping screws
http://i.imgur.com/OZ0zs.jpg
http://i.imgur.com/WWc71.jpg
Basically the lower mesh is two pieces and I used a screw for each corner.
It was really easy and is almost invisible but it adds a little protection and makes it a little different.
  • 1 month later...
  • 4 weeks later...
I'm going to do this tomorrow. A few questions. what kind if mesh did you use? I'm afraid it will rust, maybe I'll treat the mesh with a clear spray. Also did you sand before plastidip?
I just used the mesh they had at Home Depot. It was like $12 for a very large sheet. It can get very sharp when cutting, so use gloves.
I didn't sand at all before Plasti-Dip. No need to. That stuff is amazing. So far it has been holding up just fine on the mesh, even on my rims. I did about 3 light coats front and back to make sure I got a nice even coating.
