sealoss Posted January 27, 2011 Share Posted January 27, 2011 my timing belt starts to screech when i hit 5000 rpm on fast accelerations, im guessing this is just the friction from the belt, can this be something else? Link to comment Share on other sites More sharing options...
SLegacy99 Posted January 27, 2011 Share Posted January 27, 2011 Screeching? Not sure that's your timing belt. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 27, 2011 Share Posted January 27, 2011 It could be your timing belt. A bad tensioner lets the timing belt slide on the pulley and make noise. This is very bad. Check the accessory belts first. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
carnumber19 Posted January 28, 2011 Share Posted January 28, 2011 Accessory belts, like said above, are the most likely culprit, whatever you do, DON'T put the "belt dressing" on them, it will stop the squealing very temporarily, but ultimately your better served replacing the belts. If it IS your timing belt squealing; 1.) Stop revving to 5k 2.) Go get that thing replaced asap. Link to comment Share on other sites More sharing options...
johnegg Posted January 28, 2011 Share Posted January 28, 2011 if the accessory belts have been recently replaced they may just need adjusting. if they are old , adjusting may help, probably will short term, but i would have replacements on hand. just in case. Link to comment Share on other sites More sharing options...
