I Donated thefultonhow Posted March 12, 2013 I Donated Share Posted March 12, 2013 07 Spec.B, 70k mi. Coolant is pretty dark, but still has a greenish hue when not in the drain pan. Oil from the oil pan looks fine, but there is light tan foamy oil residue in the PCV system. Can't do a compression test, because the engine is currently out of the car. Oops. Thoughts? Anything else I should check? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 13, 2013 Author I Donated Share Posted March 13, 2013 Bump? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 13, 2013 Moderators Share Posted March 13, 2013 Only way to really be sure is to look at the actual gasket right? If you already have the engine out how much extra work does that involve? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
CapnJack Posted March 13, 2013 Share Posted March 13, 2013 If you already have the engine out how much extra work does that involve? This^^^ The hard part is already done. Do it while you've got it out if you are concerned. Might as well also do the timing belt while you are in there. Don't forget spark plugs. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 13, 2013 Author I Donated Share Posted March 13, 2013 Not doing the timing belt right now. Don't have the money to do it right, and I've got 35k until it's due, and I can do it without pulling the engine. I really don't WANT to do the HGs, because they're a total pain in the ass. I'm particularly not looking forward to taking off the intake cam pulleys. Subaru hired a gorilla to tighten those things down at the factory. But, I am willing to do them if I need to. I'm just not sure I need to. Does the foamy light-colored oil indicate a probable HG issue? Or are there other more likely causes? The coolant may just be dark because it was never changed. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 13, 2013 Share Posted March 13, 2013 Was the engine sitting out of the car for a while? If so, the oil could be that color from condensation just by sitting out. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 13, 2013 Author I Donated Share Posted March 13, 2013 Car hasn't been started since Friday. Engine was taken out yesterday. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 13, 2013 Moderators Share Posted March 13, 2013 Will an impact gun help with the cam pulleys? I've got an ingersoll rand electric that you could borrow if you want it--I'll be in college park on thursday evening and could loan it to you for a bit if you could meet me there. (no idea if cam pulleys are impact accessible or not...) "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
12sechatch Posted March 13, 2013 Share Posted March 13, 2013 Can't you crank it by hand for the compression test? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 If the car is not driven for a long time in the cold weather the light brown crap in the PCV system is normal. The engine has not gotten warm enough to boil the condensation out of the system. The AOS on my wagon gets it to unless the outside air temps are above 30F... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 13, 2013 Author I Donated Share Posted March 13, 2013 Okay, I think that settles it. No HG change for me. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted March 13, 2013 Share Posted March 13, 2013 Why is the engine out anyways ? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 Why is the engine out anyways ? Thanks, I was going to ask but didn't want to seem like I missed something earlier... lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 13, 2013 Moderators Share Posted March 13, 2013 clutch replacement and tgv work I believe. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 13, 2013 Author I Donated Share Posted March 13, 2013 clutch replacement and tgv work I believe. Yes, primary reason is clutch replacement. Also doing the IM gaskets and installing an oil pressure gauge sender (among other things) while it's out. Link to comment Share on other sites More sharing options...
jduani Posted March 13, 2013 Share Posted March 13, 2013 If your oil was a milk chockolate color like this http://i941.photobucket.com/albums/ad258/jduani/483135_10152432019720123_1875949660_n_zps05082fba.jpg(my 07 Spec B right around the 65K) Then you headgasket is gone... haha. If the motor is already out and you are taking the IM off anyway you might as well just do the gaskets if have an worry. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 If your oil was a milk chockolate color like this http://i941.photobucket.com/albums/ad258/jduani/483135_10152432019720123_1875949660_n_zps05082fba.jpg(my 07 Spec B right around the 65K) Then you headgasket is gone... haha. If the motor is already out and you are taking the IM off anyway you might as well just do the gaskets if have an worry. His oil was normal looking. re-read post #1. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 Yes, primary reason is clutch replacement. Also doing the IM gaskets and installing an oil pressure gauge sender (among other things) while it's out. Remember to grease the starter shaft too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
WaspGT Posted March 13, 2013 Share Posted March 13, 2013 Ugh! You have to drop the motor to change a clutch in these things??? WTF? My clutch has started slipping recently... cant effing wait Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 Now I can see the photo above, that's how my AOS looks during the cold weather. My HG 's are fine. WaspGT, some of us think it's easier to pull the engine for the clutch rather then drop the tranny. I've done both. It is easier to work on the clutch on the back of the block with it out of the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
WaspGT Posted March 13, 2013 Share Posted March 13, 2013 Now I can see the photo above, that's how my AOS looks during the cold weather. My HG 's are fine. WaspGT, some of us think it's easier to pull the engine for the clutch rather then drop the tranny. I've done both. It is easier to work on the clutch on the back of the block with it out of the car. It'll be a good time to bolt on my new 20G, do my headgasket and timing belt i guess. Just turned into a 2 day job... sweet. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 13, 2013 Share Posted March 13, 2013 It'll be a good time to bolt on my new 20G, do my headgasket and timing belt i guess. Just turned into a 2 day job... sweet. Why replace your HG's ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted March 13, 2013 Share Posted March 13, 2013 I found it a lot easier to drop the tranny to replace the clutch. Too much work involed in pulling the engine, IMO. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
GTTuner Posted March 13, 2013 Share Posted March 13, 2013 I found it a lot easier to drop the tranny to replace the clutch. Too much work involed in pulling the engine, IMO. Much, much quicker and less mess. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 14, 2013 Author I Donated Share Posted March 14, 2013 It'll be a good time to bolt on my new 20G, do my headgasket and timing belt i guess. Just turned into a 2 day job... sweet. Probably more like 3-4... I found it a lot easier to drop the tranny to replace the clutch. Too much work involed in pulling the engine, IMO. Much, much quicker and less mess. Well, I have no Extra-S and no transmission jack, so I pulled the engine instead. Made it easier to do the IM gaskets while the engine was on a stand, anyway. And I broke the seals on all the hoses around the turbo while the engine was out, so that it will be easier to swap to the 16G when the time comes. Link to comment Share on other sites More sharing options...
