tdaz250 Posted February 2, 2012 Share Posted February 2, 2012 My friends got a 91 legacy wagon 2wd...clutch is gone...or at least thats what it seems he said he would have to rev up higher to get it to engage and then one day it just stopped all together. He also might be getting rid of the car in a month or 2 and i might just buy it from him for a couple hundred bucks. Everything else seemed pretty good...he said something about cv joints but it looks like those are 65 a piece online...its got 140k on it. Only other thing i noticed was the rpms jumped a little bit when idling...i figure nothing a new fuel filter and some seafoam cant help with. But is it a pain in the ass to do a clutch on a car like this? i figure since its 2wd it would be easier...the plan would be to replace what the car needs and just drive it as a dd for good gas mileage. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 2, 2012 Share Posted February 2, 2012 Eh, the FWD's are still fun. I'd say the easiest way is to pull the engine. CV joints are usually easy enough. There can be times when stuff can go wrong though. The axle nut can get stuck to where it wont come off. The pin in the transaxle end can get stuck up in there. It's all stuff that has fixes for the most part, but it's still a pain. Otherwise it's easy enough. The idling issue may be the Idle Air Control Valve that needs cleaned, but it'd be brave trying Seafoam on an engine that's that old. You may just want to try Zmax or something instead. Seafoam can break stuff free and clog it up somewhere else. It's always a pain to do the clutch. Some people suggesting jacking up the engine instead of pulling it, but it's easier to pull it cause you have more room to work and mating it is probably gonna be about the same. But at least the times when you have the engine out it's a good chance to do the valve cover gaskets, timing belt, water pump...the stuff that's kind of annoying when it's in the car. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 2, 2012 Share Posted February 2, 2012 This is odd but the part that delayed my clutch job was disconnecting the fuel lines for the first time i coudlnt figure it but now I know. But the clutch isn't terrible the work is getting to it only takes about 25 min to put it in and torque things down then back to reassembly. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 3, 2012 Author Share Posted February 3, 2012 What would you guys do as far as maintenance ? Its got 140k and i have no idea the history. I was gonna do all the fluids and the clutch...thinking timing belt now since its only about 120 for the parts. Is a timing belt hard to do ? My grandpa is a car guru....has a lift in his garage...probably any tool i can think of besides special parts...he has a bunch of old classics & and i'm planning on doing all this at his house Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 6, 2012 Share Posted February 6, 2012 Timing belts are easy. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 6, 2012 Share Posted February 6, 2012 And the great part about these old Legacy's is that it's a non-interference engine so even if you do mess up the timing it wont hurt the engine. You just reset it and try again. And if you're gonna lift the engine out I'd do cam seals, front main seal, rear main seal, water pump, timing belt, timing belt pulley's (if yours are less than ideal), spark plugs, oil pump (if you can afford it) and valve cover gaskets. Unless you're willing to open up the engine and clean it all out. Then I'd do that too, but the seals aren't a bad idea if you have the block in the air. Just makes everything really easy to get to. When you do the transmission make sure to change out the filter inside the pan and clean the magnet and give it new fluid. Dont just give it new fluid. Someone else may have more, but that's all I can think of right now. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 9, 2012 Author Share Posted February 9, 2012 Great heres what i'm gonna order so far...seem alright? http://www.ebay.com/itm/150697052507?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.ebay.com/itm/220747435314?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Good to know about the timing though. How would i know if the timing was off? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 9, 2012 Share Posted February 9, 2012 No clue on ebay clutches or how well they work. Ask him what brand the stuff in that timing kit is. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 10, 2012 Author Share Posted February 10, 2012 Well i'm the proud new owner. 300 bucks. I'm gonna get the clutch parts from napa...its only 230 vs 200 on ebay. Cv axles are 100 at napa too for a set. Timing belt is way cheaper on ebay though. BTW where is the idle air control valve? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 10, 2012 Share Posted February 10, 2012 Good choice. Napa is OEM stuff. I would get the CV axles from Autozone as they are a lifetime warranty product. You buy it, you break it, you return it, they give you a new one. It's on the Intake Manifold. It's on the passenger side. It has a little tan/gray colored electrical box on the top of it with two screws in it. It also has a coolant line running through there so be prepared. Link to comment Share on other sites More sharing options...
1993wgn Posted February 11, 2012 Share Posted February 11, 2012 I picked up a luc clutch kit online for around 115$, so far its doing great but yeah pull the motor, do the timing belt/water pump to, its easy. hell the headgaskets were easy to if you got the motor out do that as well then you'll be solid for another 60k+ miles but that just my .02 Link to comment Share on other sites More sharing options...
tdaz250 Posted February 12, 2012 Author Share Posted February 12, 2012 Idk what route were going to go(engine out vs just pulling the trans). I might just do the timing belt somewhere down the road. I've gotten all the parts to get it going once its driveable i'll see where its at. Do you guys know if theres a fuse for the auto seat belts? Anyway...hoping to start at about 10ish in the morning on monday and have the car driving by its own power by the time it gets dark. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 14, 2012 Author Share Posted February 14, 2012 Clutch is installed. Wasnt hard at all...we just dropped the trans out. Started at 10:30 ended at 4:30. Hardest part was getting the trans back in. Now that i've driven the car it definetly needs some rotors + pads...after driving around for a little bit theres vibration when braking...i'm guessing its warped rotors. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 14, 2012 Share Posted February 14, 2012 Not sure about the fuse for the seatbelts but awesome man! I suggested pulling the engine so you could do a lot of the stuff in the air instead of bent over a car haha Probably just warped rotors. I never worry too much about that. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 15, 2012 Author Share Posted February 15, 2012 Yeah thanks for the advice. We had a lift so the only real muscle work was lifting the trans back in...that was the hardest part. Now that i've done it i think i could do it in half the time... I think all thats left mechanical wise is change the timing belt and giving the brakes some attention and then it will be where i dont have to even think twice worry wise about this thing for 60k miles(200k) Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 15, 2012 Share Posted February 15, 2012 Sounds like a sweet deal Take care of it and it'll last that long no problem. Link to comment Share on other sites More sharing options...
tdaz250 Posted February 18, 2012 Author Share Posted February 18, 2012 For the first time since i picked it up its doing that thing where it hiccups when idling....would it be that idle air control valve? where is it and how do i clean it? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 20, 2012 Share Posted February 20, 2012 That could be. It's on the intake manifold towards the passenger side strut. It as a small electrical box on it. If you take if off there you'll need a new gasket for it and it's hard to come by since most dealerships have no idea what it is you're looking for. It also has a coolant hose to be aware of. There are four bolts on it I believe and one of them is at the bottom and hard to get to. It's a lot of work, but it can be cleaned up easy enough. You could use a wire brush and carb cleaner or if you have a compressor you could buy the $10 engine cleaning kit from Harbor Freight and use it as a gas/air mixture that cleans really well. If can, mark where the electrical box was on top, but it sounds like it could use some adjustment anyway. Now is your car dying off with its idle? Link to comment Share on other sites More sharing options...
tdaz250 Posted February 21, 2012 Author Share Posted February 21, 2012 It's never died from it doing it. And it hasn't done since then either. It's weird that it only happens every once and a while Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 21, 2012 Share Posted February 21, 2012 Hmmmm. Usually if it dies it's the MAF and it'd probably run a bit worse so the IAC sounds like a good enough place to start. Also you can always find a junk IAC and change out the electrical box on the top. I've found them for $3 before. No more Legacy's in any junk yards around me though :/ Link to comment Share on other sites More sharing options...
tdaz250 Posted February 23, 2012 Author Share Posted February 23, 2012 Dang theres tons around me. 5 at the local one and i think 6 or 7 at the one thats probably half an hour away(vs 10 minutes). I'm goin there tomorrow to hopefully find a door panel & a tail light and a few other things. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted February 23, 2012 Share Posted February 23, 2012 Lucky! I may need you to get me some parts some day haha Link to comment Share on other sites More sharing options...
