MBrennan Posted January 29, 2015 Share Posted January 29, 2015 An alignment shop is telling me they cant adjust the toe on the RR or camber on the LR (08 LGT limited 5eat) to within specs. Is there a aftermarket eccentric adjustment bolt with more adjustment then the stock one? Or any options? Toe can not be adjusted any further then .17 The camber cant be adjusted any further then -1.5 Link to comment Share on other sites More sharing options...
CapnJack Posted January 29, 2015 Share Posted January 29, 2015 Guessing that the bolts are seized inside the bushing and thats why it won't adjust. You can go OEM and replace the rusted components or replace with all Whiteline components. Link to comment Share on other sites More sharing options...
MBrennan Posted January 29, 2015 Author Share Posted January 29, 2015 Im pretty sure he said the adjustment bolts were not frozen. Link to comment Share on other sites More sharing options...
CapnJack Posted January 30, 2015 Share Posted January 30, 2015 Do you have aftermarket suspension installed? Lowering springs, coilovers, etc? If you can't get into factory specs with the factory suspension, you might have some bent parts. For clarification, the bolts may not seem frozen, but they may spin with the rubber in the bushing and give a false indication they are not frozen. If they don't spin freely 360 degrees without tearing the bushing, they need to be replaced. If they do, I'm wondering if you have a bigger problem. Link to comment Share on other sites More sharing options...
