06spec411 Posted September 26, 2008 Share Posted September 26, 2008 Yeah i finally hit 30,000 and i wanted to know if theres any good threads or forums on giving LGT's a tune up. i just wanna get some after market plugs, wires and such. i have no idea what would be a good brand that may offer more performance. but i can do the job myself, so just some info on what ill need for the tune up would be sweet. thanks Link to comment Share on other sites More sharing options...
SubLGTaru Posted September 26, 2008 Share Posted September 26, 2008 You'll probably want to stick with OEM on the spark plugs. Link to comment Share on other sites More sharing options...
outahere Posted September 26, 2008 Share Posted September 26, 2008 wires? Link to comment Share on other sites More sharing options...
rjundi Posted September 26, 2008 Share Posted September 26, 2008 Take a peek in your owners/maintenance manual for specifics. Plugs are not due till 60k. I would not bother with wires. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2008 Share Posted September 27, 2008 COP (coil on plug) there are no wires to change. 30,000 you should replace the rear end fluid and manual tranny fluid. Check the air filter and may be replace it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
blackfang Posted September 27, 2008 Share Posted September 27, 2008 Yeah i finally hit 30,000 and i wanted to know if theres any good threads or forums on giving LGT's a tune up. i just wanna get some after market plugs, wires and such. i have no idea what would be a good brand that may offer more performance. but i can do the job myself, so just some info on what ill need for the tune up would be sweet. thanks No wires. Plugs are due at 60k and recommend NGK when you do. All the vehicle needs now is Oil change Rotate tires change trans fluid change coolant change brake fluid Replace air filter and check cabin filter. The rear differential can go until 45k. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
sschmelcke Posted September 27, 2008 Share Posted September 27, 2008 i have 73k miles now and when i changed the plugs at 58k they still looked great. stick with the ngk iridiums Link to comment Share on other sites More sharing options...
