mattglo737 Posted December 10, 2008 Share Posted December 10, 2008 I bought a new set of wheels for my winter tires, http://www.wheelmax.com/product.asp?ProdId=11845 Now that I have put them on, the tires rub on the wheels wells when I accelerate fast around turns, or when I have extra weight in the car, "like 1 extra 200lb person." What do I need to do to fix this without spending more than I did on the wheels??? -Matt Link to comment Share on other sites More sharing options...
rnstein69 Posted December 10, 2008 Share Posted December 10, 2008 did you go with the 35 offset? what size are the tires? Link to comment Share on other sites More sharing options...
fonts Posted December 10, 2008 Share Posted December 10, 2008 What are the size and offset of the new wheels??? Sounds like that is your problem. Link to comment Share on other sites More sharing options...
mattglo737 Posted December 11, 2008 Author Share Posted December 11, 2008 The wheels are 18X7.5 and the tires are 215X45X18. Not positive about the offset, there were two options on the website for a 35 offset and a 45 offset. I'm pretty sure I got the 35. What are we supposed to have? WEX62-187535DH-SL is the way the wheel is shown on my bill. So I would assume that meant 18X7.5 with a 35 offset... Link to comment Share on other sites More sharing options...
gf2020 Posted December 11, 2008 Share Posted December 11, 2008 I think the problem is the 45 series tire; those are too tall. I think you need a 35 or 40 series tire. Link to comment Share on other sites More sharing options...
rnstein69 Posted December 11, 2008 Share Posted December 11, 2008 I think its a combination of the wrong offset and tire size. I would have gone with the 45 offset for sure. Link to comment Share on other sites More sharing options...
PeterJMC Posted December 11, 2008 Share Posted December 11, 2008 Do you know where it is actually rubbing? When I had my 18x8s mounted I had some rubbing in the rear. It was noticeable when additional weight was in the car. The cause was a lip weight that was installed on the inside lip of the wheel. It was rubbing against the rear plastic fender liner. I fixed the problem by cutting away some of the plastic fender liner and no more rub! Link to comment Share on other sites More sharing options...
whitetiger Posted December 11, 2008 Share Posted December 11, 2008 35mm offset is no good. you need the 45mm offset wheels. the wheel sticks out too far with the 35mm offset. Link to comment Share on other sites More sharing options...
DrCloud Posted December 12, 2008 Share Posted December 12, 2008 Assuming standard tire sizing, a 215 tire on an ET35 wheel is about the same as a 255 tire on an ET55 wheel, in terms of where the outboard face of the tire is. And that seems likely to rub -- I had 245's on ET48 wheels, and they rubbed on plastic fender liner. HPH Link to comment Share on other sites More sharing options...
ilh Posted December 12, 2008 Share Posted December 12, 2008 I think the problem is the 45 series tire; those are too tall. I think you need a 35 or 40 series tire. Isn't 215/45R18 the stock size on a SpecB? It's the offset. Link to comment Share on other sites More sharing options...
mattglo737 Posted December 12, 2008 Author Share Posted December 12, 2008 After a 30min convo with the people at wheelmax.com, they will be sending me new wheels with a 45mm offset and mounting the tires on and paying for shipping. So it didn't turn out too bad... 215/45R18 is stock on spec.B. And the tires were rubbing in the back when there was extra weight and on the plastic things. I'm pretty sure that the new offset wheel will make a really big difference. Link to comment Share on other sites More sharing options...
Throttlejockey Posted December 12, 2008 Share Posted December 12, 2008 The 45 offset will make a big difference and eliminate the problem. Link to comment Share on other sites More sharing options...
mattglo737 Posted December 12, 2008 Author Share Posted December 12, 2008 Thats really good!!! Thanks everyone for your input. Oh and I just read the sticky that gives you all of the sizes you need... Very informative. Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted December 12, 2008 Share Posted December 12, 2008 http://smiliesftw.com/x/smh.gif Link to comment Share on other sites More sharing options...
fonts Posted December 12, 2008 Share Posted December 12, 2008 Glad to hear it worked out. Link to comment Share on other sites More sharing options...
