Buzzman Posted March 5, 2012 Share Posted March 5, 2012 Looking for a used up instead of buying new first and someone suggested this setup to me Link to comment Share on other sites More sharing options...
car_cursed Posted March 5, 2012 Share Posted March 5, 2012 yes, all 02+ turbos can use the same up pipe Link to comment Share on other sites More sharing options...
Buzzman Posted March 6, 2012 Author Share Posted March 6, 2012 Are you positive about this? I always hear of only 04 Sti up's being compatible. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 6, 2012 Moderators Share Posted March 6, 2012 yes, he's positive. you just don't want some of the older wrx up pipes (02-05, maybe?) because they have cats in them, just like 05/06 LGTs. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Buzzman Posted March 6, 2012 Author Share Posted March 6, 2012 Thanks for the responses and confirmation, guys. Link to comment Share on other sites More sharing options...
Heedz Posted March 6, 2012 Share Posted March 6, 2012 EVeryone puts in 04+ sti because the 02-05 has a cat too like barmanbean Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 19, 2013 Share Posted March 19, 2013 I am going to do that same swap. Can I reuse my old gaskets (assuming they are in OK shape)? Link to comment Share on other sites More sharing options...
Nrw Posted March 19, 2013 Share Posted March 19, 2013 I am going to do that same swap. Can I reuse my old gaskets (assuming they are in OK shape)? for piece of mind, I'd order some new gaskets. Pre-turbo leaks are a buzz kill. Link to comment Share on other sites More sharing options...
jbangoy Posted March 20, 2013 Share Posted March 20, 2013 Just found an 07 STi UP on nasioc for $40 he listed it in November and it fell through the cracks I guess :-D Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 20, 2013 Share Posted March 20, 2013 On another note, we apparently break the law if we decide to change our catted uppipe to a catless even if no one can really tell. So how come newer legacies/imprezas are able to get away with their already installed OEM catless uppipes? Link to comment Share on other sites More sharing options...
car_cursed Posted March 20, 2013 Share Posted March 20, 2013 Because they have the air pump. Link to comment Share on other sites More sharing options...
floater163 Posted March 31, 2013 Share Posted March 31, 2013 Will the stock heat shield fit when converting an 05 Legacy GT uppipe to a 2011 OEM WRX Hatch uppipe? Link to comment Share on other sites More sharing options...
CDubbs Posted April 1, 2013 Share Posted April 1, 2013 Removing a cat isn't what's illegal. It is tampering with the factory installed emissions equipment. You could easily pass Illinois emissions sniff test with that single cat removed because IIRC the 05 GT was a ULEV (but could fail the visual inspection). Last time I went it was OBD2 and visual inspection only. No, the name has nothing to do with bragging about 20 inch wheels... Link to comment Share on other sites More sharing options...
