Molal24 Posted April 12, 2009 Share Posted April 12, 2009 I don't know if any of you guys can help me out here...Every time I go over some minor cracks in the road I think my passenger seat rattles. I'm thinking this because when someone is in it, no rattle... I've tried adjusting the back of the seat and nothing...Still the same annoying rattle. I also tried moving the seat all the way up toward the dash and all the way back. Still nothing... Now I'm thinking maybe there's a loose screw somewhere between the back of the seat and the bottom? Anyone? Link to comment Share on other sites More sharing options...
Molal24 Posted April 12, 2009 Author Share Posted April 12, 2009 ? Link to comment Share on other sites More sharing options...
cchen1 Posted April 12, 2009 Share Posted April 12, 2009 Are you sure it's the seat? Could be the seat belt buckle rattling against the B-pillar - that's what is going on in my car. That would also explain why there is no rattle when somebody is in the seat. Link to comment Share on other sites More sharing options...
zag300zx Posted April 12, 2009 Share Posted April 12, 2009 ^^ The seat belt buckle had me going for a while too. Just needed to turn it the other way and that went away. Also both my headrests would rattle when in the down position. I fixed that by removing the headrest and squeezing the metal rods so they were slightly bent inward. That tightened everything up. Fixed! Link to comment Share on other sites More sharing options...
Molal24 Posted April 13, 2009 Author Share Posted April 13, 2009 I guess I will give that a shot...I'll tighten the headrest and buckle the seat belt in the passenger seat while I drive to school and see if thats the issue... Thanks guys.. Link to comment Share on other sites More sharing options...
Molal24 Posted April 13, 2009 Author Share Posted April 13, 2009 Def not the seat belt or the headrest...I can see the back of the seat shake and that's what causes the rattle... Link to comment Share on other sites More sharing options...
Molal24 Posted April 18, 2009 Author Share Posted April 18, 2009 bump Link to comment Share on other sites More sharing options...
camber Posted April 18, 2009 Share Posted April 18, 2009 I had a mysterious rattle from the passenger side seat that bothered me for a while. Turned out that some loose change lodged between the seat rail near the transmission tunnel. Link to comment Share on other sites More sharing options...
Molal24 Posted April 20, 2009 Author Share Posted April 20, 2009 No mine is the actual back of the seat. I can see it shake whenever I hit some cracks in the street...Really annoying. Link to comment Share on other sites More sharing options...
Cstoop Posted April 22, 2009 Share Posted April 22, 2009 Try giving the upper part of the seat a good hit. If you can hear it rattle from that, it may be a lever inside of the back of the seat. Part of the lumbar support can detach and cause this rattle. (bugged me out for the longest time) If this is the case you will have to open the back of the seat up and reattach it. Link to comment Share on other sites More sharing options...
Ultraman V Posted October 16, 2009 Share Posted October 16, 2009 Is there a write up to open the back of the seat.....my passenger seat is having the same rattle mentioned above. Thanks Link to comment Share on other sites More sharing options...
rice_rocket Posted October 16, 2009 Share Posted October 16, 2009 There's also the main bolt at the hinge.. it came loose on another seat.. just tightened it up. Link to comment Share on other sites More sharing options...
