whitrzac Posted January 15, 2017 Share Posted January 15, 2017 I searched, I know the springs are different rates, but what about the struts? Are the front struts between the 08-14 WRX and 05-09 LGT compatible? Koni is making full struts for the front of the 08-14 WRX now... Link to comment Share on other sites More sharing options...
whitrzac Posted January 17, 2017 Author Share Posted January 17, 2017 From Koni The only dimensional differences in the two strut inserts are 7mm in the extended length with the WRX 8610 1453sport (which also allows for additional 7mm of stroke). Compressed length and all other dimensions are the same. The valving of the Legacy insert is 200N higher in compression, and 650N higher in rebound. Link to comment Share on other sites More sharing options...
whitrzac Posted January 17, 2017 Author Share Posted January 17, 2017 There are currently no plans for a full strut Legacy option. We do not have graphs available for the shocks showing damping curves. The compression is approx. 18% firmer, and rebound 23% firmer. * on the legacy shock vs the WRX Link to comment Share on other sites More sharing options...
