assfast Posted September 27, 2010 Share Posted September 27, 2010 my 98 lgt 5 speed shifter rocks back and forth as if its in neutral even when its in gear any suggestions on how to fix that Link to comment Share on other sites More sharing options...
code411 Posted September 27, 2010 Share Posted September 27, 2010 You need to replace the bushing in your linkage. The bolts near your trans. actually go though the bushings. If its that loose you might want to check weather the bolts are tight at all??? Remove the center console cover and the shifter boot. A flashlight should be able to tell you where the problem is after that. Link to comment Share on other sites More sharing options...
