CrowNaza86 Posted December 18, 2014 Share Posted December 18, 2014 I had noticed the other day that the car was showing a lot of FKLC. I had done a log, but somehow it was deleted. I pulled a quick three logs on the way home from work today and only saw a small instance of FBKC, but a consistent FKLC at around 4k. DAM never changed from 1. Reading up on it, as long as FBKC is at zero and DAM at 1, I have nothing to worry about...I think. Only mod engine wise is a stage 1 Cobb AP tune and AEM dry filter. Engine has a bit over 70k on it. Can anyone discern anything from the logs? PSA- I had started the log at ~2.5k yet the excel starts at roughly ~3.5k in most of the logs. I was also not able two go to redline (6.5k). I am going to try and pull a legitimate log (2.5k to 6.5k), but figured I would post these up first.datalog1.csvdatalog2.csvdatalog3.csv Link to comment Share on other sites More sharing options...
serx7 Posted December 19, 2014 Share Posted December 19, 2014 When doing datalogging, make sure you wait a sec or so for the AP to indicate that it is indeed logging, before matting the pedal. My old AP2 would take like 1.5-2 sec to actually start logging after I hit the button. ".. Reading up on it, as long as FBKC is at zero and DAM at 1, I have nothing to worry about...I think... " ^ No, you need to also consider FLKC. FBKC if present should be small and only intermittent/rare and FLKC shouldn't show much in the way of learned corrections. I believe Cobb and many others feel that small corrections like single count -1.4 deg or less FLKC should not be cause for much concern unless it persists rather than learns itself out over time. I personally don't like to see -any- FLKC at all, and as long as FBKC only appears very intermittently, I'm cool. Your datalog2 does -not- show a 'small instance' of FBKC. It shows a -3.85 deg timing pull in response to noise heard from the knock sensor. That implies that at some point before 3470 RPM (start of your log), the ECU heard noise and pulled timing more than once before things quieted down and the ECU decayed the FBKC back to 0. Of similar concern is that there's a -3.5 deg FLKC correction in the 5213+ rpm range. That implies that at some point in the ~2.5 g/rev load and 5200+ rpm range, the ECU pulled timing more than once in response to noise. Your log shows the ECU starting to decay the -3.5 deg FLKC at 5395 rpm (retard increment is probably +0.35 deg hence the -3.15 deg FLKC at the end of your log), but the fact that it pulled that much timing as a learned correction is a concern. What are your AF Learning 1A, B, C, D? Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 19, 2014 Author Share Posted December 19, 2014 Thanks for the reply. That's strange since I had waited about 2secs before going WOT. I'll wait a bit more next time before beginning. I understand FKLC & FBKC are methods the ECU uses to correct knock and that very small amounts to none are what the goal is. I was just going off the stickied knock thread. I guess that wasn't a small instance, so that's my mistake on verbage. I did not look into those, but will do a log with all four the next chance I get and post here. Link to comment Share on other sites More sharing options...
heiche Posted December 19, 2014 Share Posted December 19, 2014 can you post an LV? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 19, 2014 Author Share Posted December 19, 2014 I'm on an AP Link to comment Share on other sites More sharing options...
heiche Posted December 19, 2014 Share Posted December 19, 2014 I'm on an AP sorry, thought that was possible. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 23, 2014 Author Share Posted December 23, 2014 Sorry for the delay. Attached are two, smoother, logs. I did not log AF Learning A-D, but will do so when I return from vacation.2.2-6.3K.csv2-6K.csv Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 29, 2014 Author Share Posted December 29, 2014 Buuump. Should I redo the logs? Is there anything noticeable in the tables? Link to comment Share on other sites More sharing options...
serx7 Posted December 29, 2014 Share Posted December 29, 2014 your 2.2-6.3K log shows double count FLKC way @ the top of the rev range. the 2-6K log shows some FLKC that appears to decay to -0.35 deg correction after 5800 rpm and then returns to -1.4 shortly afterwards, but that might just be b/c you're going through different load/rpm cells in the FLKC table. either way, i personally would prefer to see nothing in FLKC, or very intermittent single count -1.4 deg corrections that learn themselves out and don't reappear shortly afterwards. don't forget to grab a quick log, fully warmed up @ idle, that includes AF Learning 1A, B, C, D. Link to comment Share on other sites More sharing options...
CrowNaza86 Posted December 29, 2014 Author Share Posted December 29, 2014 serx7 thanks, I'll be grabbing a log of A-D when I return from vacation. In regards to the FLKC, should I begin looking into anything particular? Compression test, etc? Trying to learn what I can from this, with what little time I have, so I'm more knowledgeable in the future. I'm guessing an A/F log will help narrow things down a bit and point towards the car running lean/rich/etc? Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 6, 2015 Author Share Posted January 6, 2015 Here is the A/F Learning A-D log. Car was warmed up and @ idle.AF Learning A-D.csv Link to comment Share on other sites More sharing options...
Subieaction Posted January 6, 2015 Share Posted January 6, 2015 B is a little high but from reading on some threads on nasioc it should be +/- 5% Link to comment Share on other sites More sharing options...
Subieaction Posted January 6, 2015 Share Posted January 6, 2015 Maybe try replacing your AEM filter for an OEM one. Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 6, 2015 Author Share Posted January 6, 2015 I was thinking I should do that as a first step. I believe I still have an OEM filter somewhere. Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 22, 2015 Author Share Posted January 22, 2015 OK so that took awhile, I had to order a new filter. Here is A-D log, a bit over a min of logging. I did reset ECU after installing OEM filter. I will be logging a WOT run the next chance I get.datalog3.csv Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 22, 2015 Author Share Posted January 22, 2015 Crap, I probably shouldn't have reset ECU before logging this. I just realized B-D are blank... Link to comment Share on other sites More sharing options...
Subieaction Posted January 22, 2015 Share Posted January 22, 2015 Just give it some time and drive for a bit it will adjust itself Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 23, 2015 Author Share Posted January 23, 2015 Here is a correct log of A-D. A/F D is pulling -8 to -9 when it should usually be around +/- 5%? Is the fact that ignition timing is going up and down an issue related to this? Fuel is being pulled so timing is advanced/retarded?datalog1.csv Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 26, 2015 Author Share Posted January 26, 2015 On the way to work last night and return trip home this morning, I was picking up FBKC @ -7. This was cruising @ 65-70. The trip to work I also picked up FKLC @ -1.4, but on trip home it was 0 entire way. I wasn't going to worry about it, but it kept popping up multiple times throughout the drive...so now I'm worried about it. I'm going to look into have a compression/smoke test done soon to see if that will yield any results. Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 29, 2015 Author Share Posted January 29, 2015 Anyone have an opnion on what the issue may be? Link to comment Share on other sites More sharing options...
Subieaction Posted January 29, 2015 Share Posted January 29, 2015 Get the test done and make sure everything is tied down. Heat shields clean your maf as well just to make sure. What mods do have on your car? Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 29, 2015 Author Share Posted January 29, 2015 Get the test done and make sure everything is tied down. Heat shields clean your maf as well just to make sure. What mods do have on your car? Heatshield is on tight and I cleaned the MAF this past weekend. I'll hopefully knock out the test this weekend. Cobb OTS tune, turbo blanket and axleback exhaust are the only mods I think could be affecting it. Link to comment Share on other sites More sharing options...
Subieaction Posted January 29, 2015 Share Posted January 29, 2015 What tune stage 1 93 map or 91 map? Link to comment Share on other sites More sharing options...
Subieaction Posted January 29, 2015 Share Posted January 29, 2015 I say that because if you are on 93 switch to 91 and put in 93 gas. It might help. At least it helped me when I was knocking on the 93 map Link to comment Share on other sites More sharing options...
CrowNaza86 Posted January 29, 2015 Author Share Posted January 29, 2015 I say that because if you are on 93 switch to 91 and put in 93 gas. It might help. At least it helped me when I was knocking on the 93 map I'm on the 93 map, but I'll try that out thanks! Link to comment Share on other sites More sharing options...
