Driver Door Sticking
Lately, my driver side door has been giving me some problems. When you go to open it, it goes about an inch or so without problem, but then you have to pull a lot harder than normal to get it to budge. I could not see anything catching when opening the door. Any ideas?
Spray the crap out of it with WD40. That means outside into the area exposed with the handle up, the inside on the where ever you can get to it. near the latch.
Don't worry about over spray. The Subie lock system can be a bear. If you don't go crazy with lube now, you may be stuck with a door that will not unlock.
And that is a real PITA
"Belief does not make truth. Evidence makes truth. And belief does not make evidence."
