DCCD Control Install Location
S4
Can anyone share pictures of where they installed controls for their DCCD controller (DCCDPro or similar)? Ideally I'd like to use the STI controls, but I'm not certain that they'd fit in a 2005. I think there may be some space around the shifter...
Ashtray is a good, clean, location.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
  • 3 months later...
Im looking for the same thing, trying to determine where to mount so.....
:needpics:
I was thinking behind the parking brake lever near the console cubby, but not sure both will fit there.
I am also considering in the fuse block door on the left below the mirror controls.
I got the factory STI control knobs for mine but thanks for the pics. I see the knob what is the other connection?
Also is that shifter knob the $140 STI knob that looks like the momo?
What linkage did you use to get it centered? Spec B? Looks pretty short what shifter did you use?
where did u put your g force sensor and dccd box?
The button toggles it between manual and automatic mode, and also changes illumination based on output of the diff via a blue LED ring.
Is is the leather/aluminum shift knob that can be seen here: http://www.fastwrx.com/sti20leshkn5.html
I'm pretty certain it's the SpecB shift linkage. I believe the DCCD box is behind my stereo, but can't tell you more details since Six Star Motorsports did the install.
HOly shit. I didn 't realize so many people made the DCCD conversion. That is sick! Isn't that a ton of work/ money?
Is it an all new Tranny, diff, etc?
Rehab is for quitters.
Is yours a short throw shifter, it look shorter from the stock STI or Spec B.
If it is do you know what one it is?
I just ordered the spec b short throw at the recommend of uncle mat.
If you can let me know what shifter they used in yours and any other parts used with that. It would be good. I have understand you have to get a a couple parts that have to do with the stay rod to help center the shifter on the LGT.
35041AG020
35031AG020
http://legacygt.com/forums/showthread.php/6mt-master-swap-thread-107137.html?p=3073632
  • 2 months later...
Here you go! Two pictures - one with the arm rest up, and the other with it down. It works great here.
Have any close ups of how you attached the boot? Did you do it like Hammer?
Also, Id really like to see your shifter under that boot, it seems way shorter than my STI STS for the spec b
  • 2 months later...
