David E Posted August 17, 2016 Share Posted August 17, 2016 I did search and did not find any threads on lifting an Outback. Anyone have any experience / advice on lifting an Outback? Tks. Link to comment Share on other sites More sharing options...
wish Posted August 18, 2016 Share Posted August 18, 2016 use forester suspension Link to comment Share on other sites More sharing options...
thedeadhp Posted August 18, 2016 Share Posted August 18, 2016 Going off of what wish said, get forester xt struts and they should bolt right on, I think its a 1-1/2 inch lift. Look up lifting WRX and theres alot more on there. we use the same suspension as GD based imprezas. Link to comment Share on other sites More sharing options...
twisty Posted August 18, 2016 Share Posted August 18, 2016 http://legacygt.com/forums/showthread.php/1996-subaru-legacy-l-wagon-awd-4-lift-193333.html this guy did it to a L wagon. im gonna do forester struts, probably ironman springs http://www.subtle-solutions.com/product_info.php?products_id=351 and likely spacers http://www.subtle-solutions.com/product_info.php?products_id=479 as well. and mebbe trailing arm spacers to fix the offset http://www.subtle-solutions.com/product_info.php?products_id=398 and then get a bigger tire. and maybe new, longer axles. and maybe a bit more torque. and a good stereo, or a built in kuh-kuh-kuh-coolah Link to comment Share on other sites More sharing options...
David E Posted August 19, 2016 Author Share Posted August 19, 2016 I guess my further question is will the Forester struts raise an Outback? I know they will lift a "regular" sedan or wagon.. Link to comment Share on other sites More sharing options...
Brighton96 Posted August 19, 2016 Share Posted August 19, 2016 I guess my further question is will the Forester struts raise an Outback? I know they will lift a "regular" sedan or wagon.. In my experience, installing Outback suspension on a normal legacy wagon or sedan will bolt right in and will lift it about and 1-1.5in BUT then the struts will rub in the strut towers. Link to comment Share on other sites More sharing options...
thedeadhp Posted August 19, 2016 Share Posted August 19, 2016 They could, but not by much. the biggest "lift" the v2.0 Gen 2 outback has is that it has a few spacers in the suspension and drive line that make it more capable of being lifted. Safely that is. Link to comment Share on other sites More sharing options...
twisty Posted August 19, 2016 Share Posted August 19, 2016 In my experience, installing Outback suspension on a normal legacy wagon or sedan will bolt right in and will lift it about and 1-1.5in BUT then the struts will rub in the strut towers. my outback struts were the same width as the legacy struts, what rubs? ive got an outback, L wagon, GT sedan and a forester, i can do measurements if needed. one thing ive been meaning to measure is the outback to forester for length, i want to know which one is longer (if any, and by how much) from lower support to upper bolt hole. Link to comment Share on other sites More sharing options...
Brighton96 Posted August 19, 2016 Share Posted August 19, 2016 my outback struts were the same width as the legacy struts, what rubs? ive got an outback, L wagon, GT sedan and a forester, i can do measurements if needed. one thing ive been meaning to measure is the outback to forester for length, i want to know which one is longer (if any, and by how much) from lower support to upper bolt hole. My car is a Legacy wagon, NOT an Outback and I'm not sure what parts were on the car when I got it because the PO had it lowered on coilovers and before selling it to me he threw on junkyard struts. But I went to Outback struts and mounts but retained the junkyard coil springs and now the base of the coil spring mount rubs the inner strut towers on the rear and then the upper coil spring mount rubs the inner strut tower on the fronts. Link to comment Share on other sites More sharing options...
twisty Posted August 22, 2016 Share Posted August 22, 2016 weird. i have an outback and a L wagon. and a GT sedan. those things are interchangeable across the board, as far as ive found so far. hell, the 98 two piece headlights fit on my 95 L wagon, even has the square holes already in the frame for the pieces that didnt exist yet. Link to comment Share on other sites More sharing options...
nickramsey539 Posted September 7, 2016 Share Posted September 7, 2016 I lifted mine. Foresters are about the same hight as outback so idk why people use forester struts. Il get pics of my car in a bit Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
twisty Posted September 7, 2016 Share Posted September 7, 2016 ive always wondered if the struts had the same clearance for tires from outback to forester, i am going to measure both when i start my forester project. the only thing that would sway me either way is if there is a difference in tire clearance between the two, but im not holding any high hopes for it since they are both at about 7.5" of clearance. mainly just a curiosity that my brain needs me to find out. Link to comment Share on other sites More sharing options...
