kingtaco Posted June 12, 2012 Share Posted June 12, 2012 Hi guys, I have a 98 legacy gt. I've had it for awhile, but before I went away to school the exhaust rotted and snapped off just after the cat. I took it in to get looked at and the guy said I just need a cat back exhaust and he won't be bending the pipes so it needs to be a direct fit. So here's what I'm wondering: I found this exhaust and I'm wondering if it will work well as a replacement exhaust since there isn't much info on it: http://www.1aauto.com/1A/Mufflers/Subaru/LegacyOutback/1AEMK00132/576203?utm_campaign=gb_api_nobr&utm_medium=comparisonshopping&utm_source=google_base&utm_content=EMK I don't care if it isnt the best exhaust performance wise or loud but I would actually like a little noise. So I'm also wondering if anyone knows of a complete cat back out there or one that would be can be put together that would be better than the one I found. Thanks a lot guys, any help is appreciated Link to comment Share on other sites More sharing options...
subikid90 Posted June 13, 2012 Share Posted June 13, 2012 Your best bet is to find a muffler shop, not a mechanic, and have them bend you up a stainless exhaust then use a vibrant or borla muffler with an 18" resonator. 2.5" tubing is the ideal size for NA subarus. Throw a set of borla knock off headers from ebay and you will have a nice boxer rumble. And that exhaust will not fit, it is made for an outback which is longer than the sedan. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted June 13, 2012 Share Posted June 13, 2012 2.25" is going to be best, 2.5" causes the loss of too much back pressure unless you're running grinded cams or other internals +1 to everything else Link to comment Share on other sites More sharing options...
kingtaco Posted June 13, 2012 Author Share Posted June 13, 2012 Alright thanks a lot guys. Any idea how much more expensive getting a custom exhaust would be, rather than having this one installed? also i forgot to mention it is a wagon not a sedan but that doesnt really matter Link to comment Share on other sites More sharing options...
0Tyrael0 Posted June 13, 2012 Share Posted June 13, 2012 Your best bet is to find a muffler shop, not a mechanic, and have them bend you up a stainless exhaust then use a vibrant or borla muffler with an 18" resonator. 2.5" tubing is the ideal size for NA subarus. Throw a set of borla knock off headers from ebay and you will have a nice boxer rumble. And that exhaust will not fit, it is made for an outback which is longer than the sedan. +2 for that My best friend just had one made for his 2.2 wagon. Local muffler shop did it for only 250. Ill check into what all that included. But I know it was catback. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 13, 2012 Share Posted June 13, 2012 mine cost $225 for an 18" resonated catback to muffler and install on oem hangars Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 13, 2012 I Donated Share Posted June 13, 2012 And that exhaust will not fit, it is made for an outback which is longer than the sedan. By a whole whopping few inches. Overall length of the Outback is 185.8 (part of that being bumpers) and the sedan is 180.9. The wheel bases differ from about 2 inches irrc -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
gergeek Posted June 19, 2012 Share Posted June 19, 2012 Its probably just the midpipe that rotted out...you can go to a junk yard and get one for $70 and install it yourself...maybe even sand and paint it to avoid rust...Get some rust cutter and let the bolts soak over night..just replace the bolts with stainless steel bolts....its a pretty easy install. Make sure you get the gasket seals, or else you might have exhaust leaking into your car. Good luck Link to comment Share on other sites More sharing options...
joshtarmy1 Posted May 5, 2013 Share Posted May 5, 2013 Costed me $100 to replace the pipe from the rear cat to the muffler. Meineke just bent a straight pipe for the whole length. There was no resonator on it in the first place. Never seen so many cheap exhaust clamps on an exhaust. Still have the original muffler though. Going to replace that with a 2.25" Magnaflow muffler soon Link to comment Share on other sites More sharing options...
WESTcoast Posted May 6, 2013 Share Posted May 6, 2013 +3 to what everyone has said, find a exhaust shop near your (i'd say do some yelp searches to find best price/quality ratio) and have them do the guessing work with the exhaust you bring them. Link to comment Share on other sites More sharing options...
