balteron Posted December 11, 2012 Share Posted December 11, 2012 1997 subaru legacy outback automatic with 167000 and no abs but not throwing any codes for it and also no cel's and all i get is alot of front wheel spin and its driving me bonkers because i have no AWD now:( Link to comment Share on other sites More sharing options...
Stang70Fastback Posted December 11, 2012 Share Posted December 11, 2012 Is there a fuse in the FWD fuse holder located in the engine compartment? If you are looking into the engine bay it is located in the upper left corner (passenger side) and is a lone, black fuse holder with a flip top. Link to comment Share on other sites More sharing options...
johnegg Posted December 11, 2012 Share Posted December 11, 2012 how long have you had the car? has it always been this way or did it just develop recently? is there a drive shaft going to the rear? do you have a FWD light on the dash? is there a fuse in the FWD fuse holder under the hood, passenger side, near the firewall and the wiper motor? unplug the TCU under the dash, or the largest wire connector on the rear of the engine, passenger side, and drive the car in tight circles. you will be in limp mode, 3rd gear only, and you should have TORQUE BIND. no TB means that there is a mechanical problem causing the no awd, and probably in the extension housing on the rear of the trans. maybe a busted clutch drum or just a lot of wear on the clutch discs limiting the function. Link to comment Share on other sites More sharing options...
balteron Posted December 11, 2012 Author Share Posted December 11, 2012 I already checked the fwd and it was not in there. I will try unplugging the TCU and see how that goes... would a bad speed sensor cause this also? Link to comment Share on other sites More sharing options...
johnegg Posted December 11, 2012 Share Posted December 11, 2012 absolutely, but it would / should also throw a code. does the speedo work? if the front speed sensor fails the ECU will use the rear speed sensor to control the engine, but the speedo and the AWD power to the rear will not work. if the rear speed sensor fails, and this is almost NEVER heard of, the AWD will not work. does the Check Engine light come on before you start the car??? how long have you had the car??? has the car always had this issue or is it a recent development.???? Link to comment Share on other sites More sharing options...
balteron Posted December 11, 2012 Author Share Posted December 11, 2012 ^a month and only noticed when we got some snow and wheels spun, and yes there is a drive shaft going to the rear, no fwd light on unless i put in the fuse. Link to comment Share on other sites More sharing options...
balteron Posted December 11, 2012 Author Share Posted December 11, 2012 well im gonna scan it again tonight after work... my abs would start pumping the brakes when i was on dry roads so i took out the fuse Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 12, 2012 I Donated Share Posted December 12, 2012 The automatic transmission is front wheel bias, so your front wheels will spin before your rear wheels will -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
balteron Posted December 13, 2012 Author Share Posted December 13, 2012 speedo works fine and so i unplugged tcu and had no TB so its looking like a mechanical problem in the housing...atleast ive narrowed it down Link to comment Share on other sites More sharing options...
compsurge Posted December 13, 2012 Share Posted December 13, 2012 What kind of tires are on your car? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted December 13, 2012 Share Posted December 13, 2012 Rubber. Link to comment Share on other sites More sharing options...
johnegg Posted December 13, 2012 Share Posted December 13, 2012 mine are made of snow. Link to comment Share on other sites More sharing options...
compsurge Posted December 13, 2012 Share Posted December 13, 2012 IDK, but maybe tires that don't have any traction will result in a lot of wheel slippage going through an open diff. Just sayin'. Link to comment Share on other sites More sharing options...
balteron Posted December 13, 2012 Author Share Posted December 13, 2012 could be possible but highly doubtful considering they are almost brand new and provide amazing stability when driving down the road in about six inches of snow with only FWD...I just simply dont have AWD because of a no bueno clutch is what im figuering but i will have a closer look this weekend Link to comment Share on other sites More sharing options...
spooln30 Posted December 15, 2012 Share Posted December 15, 2012 I have good thread tires but their cheap ones and I also get front wheel spin when it's wet outside. My rear tires do spin fine. Link to comment Share on other sites More sharing options...
spooln30 Posted December 15, 2012 Share Posted December 15, 2012 Does TCU stand for transmission control unit? And its located under the dash on the drivers side? I think I know where it is due to just replacing my heater core a few months back. I think I'll check mine out as well. Thx guys. Link to comment Share on other sites More sharing options...
