AGR-LGT Posted February 8, 2009 Share Posted February 8, 2009 Hey guys, I have a new ACT Hd and WRX flywheel in my car....Ever since install it makes rattles at lower rpms when on decel Ive read that some chatter is normal for Aftermakret clutchs of course, but is there anything i can do to quiet it down...I thought i saw someone put a spring on something to solve it...??? Nosie is realyl reuining the interior comfort of the car.. thanks Brandon Link to comment Share on other sites More sharing options...
f85stealth Posted February 10, 2009 Share Posted February 10, 2009 Hey guys, I have a new ACT Hd and WRX flywheel in my car....Ever since install it makes rattles at lower rpms when on decel Ive read that some chatter is normal for Aftermakret clutchs of course, but is there anything i can do to quiet it down...I thought i saw someone put a spring on something to solve it...??? Nosie is realyl reuining the interior comfort of the car.. thanks Brandon Thats why the HD version is not a good choice for a daily driver. I am looking for a new clutch right now too Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2009 Share Posted February 10, 2009 I installed SD4-HDSS (STI style) along with 6-speed transmission and stock STI fly and I also get it Link to comment Share on other sites More sharing options...
AGR-LGT Posted February 10, 2009 Author Share Posted February 10, 2009 if its the anture of the beast then I can live with it...just want to make sure all is weel Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 10, 2009 Share Posted February 10, 2009 Might be a break-in issue? Link to comment Share on other sites More sharing options...
HansGT Posted February 10, 2009 Share Posted February 10, 2009 My HD clutch and OEM WRX fly only has slight noise in very low RPM...when you should actually be in another gear. About 6-8 months after install the pitch fork became loose. Could feel and hear it. The shop fixed it. Now after another 6 months I have a rattle/clunky sound when I initially get on and off the gas. It does it in every gear...seems something has loosened up. Can't feel anything through the pedal (btw...drives ok) Ah..aftermarket and mods.... Link to comment Share on other sites More sharing options...
TravisS Posted February 10, 2009 Share Posted February 10, 2009 I've got the ACT clutch + LWFW. I'd imagine my gear chatter is a bit worse (chatter in any gear, at any RPM) and I would be interested in a way to calm it down a bit if that's even possible. Have had it on for nearly a year now though and I can pretty well ignore it by now. Link to comment Share on other sites More sharing options...
PeterJMC Posted February 10, 2009 Share Posted February 10, 2009 Slap on some sound deadener Link to comment Share on other sites More sharing options...
FourMoBro Posted February 10, 2009 Share Posted February 10, 2009 I get chatter only on downshifts. the only way to make it subside is to put a little gas pedal into it, which defeats the purpose of downshifting.....then again, its only ~150miles on it so far.. Link to comment Share on other sites More sharing options...
HansGT Posted February 11, 2009 Share Posted February 11, 2009 My HD clutch and OEM WRX fly only has slight noise in very low RPM...when you should actually be in another gear. About 6-8 months after install the pitch fork became loose. Could feel and hear it. The shop fixed it. Now after another 6 months I have a rattle/clunky sound when I initially get on and off the gas. It does it in every gear...seems something has loosened up. Can't feel anything through the pedal (btw...drives ok) Ah..aftermarket and mods.... Heat shield came off my turbo. Clutch ok! Link to comment Share on other sites More sharing options...
Brookmastr Posted May 12, 2009 Share Posted May 12, 2009 spec 2+ on for 1500 or so and from the start i had a rattle/chatter decelerating. My tuner assured me its fine and its flywheel chatter. Nothing is wrong it just is what it is. No way to cure it mybe microbalance and reduce a little but it will always be there. The flywheel is a lot thinner, the stock flywheel is dampened to not make noise. So got to live with it or go back to stock is your only option. Link to comment Share on other sites More sharing options...
AngryLitho Posted May 13, 2009 Share Posted May 13, 2009 +1 Link to comment Share on other sites More sharing options...
AGR-LGT Posted July 28, 2009 Author Share Posted July 28, 2009 its got quieter over time...still not the best tho Link to comment Share on other sites More sharing options...
Wangspeed Posted July 29, 2009 Share Posted July 29, 2009 NOOOOOOOOOOOOOooooooooooooooooooooooooo!!!! Why couldn't I have seen this thread 2 weeks ago? I just had an ACT put in. Guess what's noisy now? Primarily happens on very very light decel/accel, and sometimes, but rarely, at idle. It's not so much the volume, but the sound. Warren Link to comment Share on other sites More sharing options...
trackhore Posted July 29, 2009 Share Posted July 29, 2009 Is this not the same noise that was cured putting a return spring on the clutch fork where the slave cylinder pushes on it? Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2009 Share Posted July 29, 2009 No. I have 6MT and ACT clutch (and the 6MT has that spring stock) and it still has the decel noise. Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 29, 2009 Share Posted July 29, 2009 I was thinking about getting a new clutch/flywheel next year but didn't want any noise. I guess i'll be putting in another stock unit. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
trackhore Posted July 29, 2009 Share Posted July 29, 2009 No. I have 6MT and ACT clutch (and the 6MT has that spring stock) and it still has the decel noise.Ah, okay. Picture of said spring? Curious what the OEM solution looks like. Link to comment Share on other sites More sharing options...
AGR-LGT Posted July 30, 2009 Author Share Posted July 30, 2009 it wont fix a act rattle... Link to comment Share on other sites More sharing options...
Kevskate99 Posted August 1, 2009 Share Posted August 1, 2009 Get used to it. I've had mine on for three years. Still get a lil rattle on decel. Did notice it got better after a few thousand miles though, But still always will hear it a lil. Link to comment Share on other sites More sharing options...
fonts Posted August 2, 2009 Share Posted August 2, 2009 Wow. I'm running the ACT HD with STi flywheel as well. Certainly there is a little bit of chatter. Thankfully I'm not experiencing noise that I would categorize as "ruining my interior comfort" Link to comment Share on other sites More sharing options...
Wangspeed Posted August 2, 2009 Share Posted August 2, 2009 Yeah, I definitely wouldn't categorize it as that bad of a noise, but the type of noise makes me, and others think "something's loose". I'm kind of driving around it by staying on the gas lightly as much as I can, and shifting to neutral to coast to a stop, which is kind of a pete peeve of mine, but I'm left with little choice now. Or we can all just get louder exhausts or crank the stereo up, both of which also fix the problem... Warren Link to comment Share on other sites More sharing options...
TSiWRX Posted August 6, 2009 Share Posted August 6, 2009 Could be that my exhaust is masking the noise, but I honestly haven't had this problem, yet (about 250 miles into break-in of my SB5-HDMM + OEM '06/'07 WRX fly pairing). Sure, I've got some chatter when I'm not giving it enough gas when starting out, but that's honestly more my problem, in terms of technique, than anything else. Similarly, I also get rougher-than-supposed-to 1st-to-2nd upshifts and also 3rd-to-2nd heel-and-toe downshifts when I mismatch , but again, that's honestly more my fault than anything else..... So far, I'm loving it - it's much more pleasurable (and I'm smoother with it, too), than the OEM clutch and that dual-mass fly. After 4+ years of the LGT, I still couldn't be silky smooth with it, whereas about 50% of the time now, I'm really smooth with the current combo. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
JoeFromPA Posted August 6, 2009 Share Posted August 6, 2009 Welp, there goes my plan for world domination....I mean an ACT HD.... Gonna start focusing on WRX clutches, as for some reason they are so much easier to modulate for me.... Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 6, 2009 Share Posted August 6, 2009 lots of noise from my spec stg2 and lwfw on decel also probably gonna go back to the stock fw if my trans ever needs to come out for some reason Link to comment Share on other sites More sharing options...
