generaljoe67 Posted November 20, 2014 Share Posted November 20, 2014 suddenly my 2005 Legacy GT will not start it just cranks and cranks no sign of starting what so ever. Assistance needed. Please respond. within the past month all plugs have been changed ,mass air flow sensor changed, upflow o2 changed. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2014 Share Posted November 20, 2014 I'm guessing fuel pump. I gather there's no CEl... Depending on how mechanical you are, you could break a fule line loose and get an idea how much pressure there is in the system. If you know what your doing. The engine grounds would be another place to check and make sure they are all in good shape and clean. But I doubt they would cause this issue all of a sudden. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 20, 2014 Share Posted November 20, 2014 Crank sensor Link to comment Share on other sites More sharing options...
Stewy612 Posted November 20, 2014 Share Posted November 20, 2014 sounds like fuel pump to me. Link to comment Share on other sites More sharing options...
xruffxryderz91 Posted November 20, 2014 Share Posted November 20, 2014 I know this is a pain but check all your fuses and check your battery. Easiest place to check Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2014 Share Posted November 20, 2014 Good ideas ^ there are a few easy things to check. hope it's something cheap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Redryan98 Posted November 20, 2014 Share Posted November 20, 2014 could also be fuel pump relay. Which is a huge PIA to get to Do you hear anything from the fuel pump when you turn the ignition on (but don't start the car) Link to comment Share on other sites More sharing options...
MrTris Posted November 20, 2014 Share Posted November 20, 2014 could also be fuel pump relay. Which is a huge PIA to get to Do you hear anything from the fuel pump when you turn the ignition on (but don't start the car) This is a good one; turn key to ACC, then put your ear to the backseat. Should be able to hear it clicking. Link to comment Share on other sites More sharing options...
MrTris Posted November 20, 2014 Share Posted November 20, 2014 suddenly my 2005 Legacy GT will not start it just cranks and cranks no sign of starting what so ever. Assistance needed. Please respond. within the past month all plugs have been changed ,mass air flow sensor changed, upflow o2 changed. Did it run AFTER all that was changed, or did you do it all at once and now it won't start? Link to comment Share on other sites More sharing options...
