slvr08lgt Posted February 16, 2013 Share Posted February 16, 2013 Hey fellow tuners..the other day when I flashed the stage 2 tune I noticed there was a map called low wastage and did a little reading on cobbs website about it. I couldn't real understand exactly what it is or does. The way it was explained was if your at a low rpm and go wot and sometimes it causes you to over boost and this fixes that problem. If any of you experienced tuners could help out and explain it a little better and if that low waste gate map is sill a stage 2 93 oct map, it is listed under the stage 2 maps...thanks in advance Link to comment Share on other sites More sharing options...
slvr08lgt Posted February 16, 2013 Author Share Posted February 16, 2013 Bump..No one knows anything about this Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2013 Share Posted February 17, 2013 Read this to understand what wastegate is first and you'll have a much better understanding of why you may need a low or high wastegate map.... Although Cobb really should call it a low WGDC or high WGDC map to be perfectly correct, since the map they label as "low wastegate" actually uses more of the WG. WGDC = WasteGate Duty Cycle. The more WGDC there is, the more closed your wastegate door is, and thus the less your wastegate is being utilized. If someone says, "you need to wastegate more" that means you need less WGDC, and vice versa. http://www.cobbtuning.com/Technical-Articles-s/70674.htm After you read that, what I said above will make sense. Link to comment Share on other sites More sharing options...
slvr08lgt Posted February 17, 2013 Author Share Posted February 17, 2013 Ok so a lot of it made sense..I take it as if you are over boosting slightly everyonce in a while you should use the low wastegate map? Is that correct/ that's the way I'm taking t from reading that article Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2013 Share Posted February 17, 2013 Yes, that's correct. If you're having a problem with overboosting, less WGDC is what you need, which the Cobb "low wastegate" map (named incorrectly IMHO) should help with. I've also posted in your other thread too with some input. You should post a log up of your overboost condition. Also, has the weather been significantly cooler lately? That will usually cause a larger boost spike than normal and if a map isn't adjusted well for that, you'll hit the boost cutoff. Link to comment Share on other sites More sharing options...
slvr08lgt Posted February 17, 2013 Author Share Posted February 17, 2013 I haven't had a chance to log yet. I over boosted 3 times but only to 18 psi and I was at a lot rpm and floored it when it happened. Other ten those times everything seems to be good Link to comment Share on other sites More sharing options...
slvr08lgt Posted February 17, 2013 Author Share Posted February 17, 2013 If you use that low wgdc map is it still about the same power and torque output as the stg 2 93 oct map or 91 Link to comment Share on other sites More sharing options...
Indiglow Posted February 17, 2013 Share Posted February 17, 2013 if you're not throwing a cel for wastegate performance then don't worry about it. Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2013 Share Posted February 17, 2013 ^-- What he said. You're not "overboosting" per se. You're spiking, which is perfectly normal. If you're throwing the CEL and hit fuel cut (you'll know it, your car will feel like Godzilla put his foot down on it), then you should look into it more. Link to comment Share on other sites More sharing options...
slvr08lgt Posted February 17, 2013 Author Share Posted February 17, 2013 Sounds good..thank you everyone for clearing that up Link to comment Share on other sites More sharing options...
