ivonr Posted February 27, 2016 Share Posted February 27, 2016 My mechanic friend saw that I have quite the set of keys on my key ring and mentioned that the weight of all of those keys hanging off of the ignition can actually cause damage to the system over time…has anyone ever heard of this? Link to comment Share on other sites More sharing options...
Holla Posted February 27, 2016 Share Posted February 27, 2016 Yeah, it's definitely possible. I haven't heard of any lgt specific failures but it's not a good idea to have a bunch of weight hanging off the key when it's in the ignition. The only other thing I have on my car key ring is the fob. Link to comment Share on other sites More sharing options...
ivonr Posted February 27, 2016 Author Share Posted February 27, 2016 I've got about 6 other keys hanging off of mine... so I will get a quick-disconnect attachment to avoid causing any L-T damage Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2016 Share Posted February 28, 2016 I guess you missed the problem with Chevy's a couple years back. The weight of all those keys would cause the car to shut off while driving. They had some cheap plastic part the wore. Car key and house key and the fob is all you should have. Oh you have an 08, minus the fob. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 28, 2016 Share Posted February 28, 2016 Chevy had issues dating back to 2002 due to a major design change that was flawed. I've never personally see an ignition tumbler go bad because of keys but that's not to say it can't happen and that it would be okay to have 40 keys on the ring. Link to comment Share on other sites More sharing options...
quick4dr Posted February 29, 2016 Share Posted February 29, 2016 saw it all the time at when working at Acura, 08-12 MDX all the time, RL too. havnt particularly heard about it in subarus, but I suppose it can really happen to any ignition given heavy enough keys Link to comment Share on other sites More sharing options...
whitetiger Posted February 29, 2016 Share Posted February 29, 2016 i hang 10lb weights from my key ring. i have problems putting that back in to my pocket though. Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 29, 2016 Share Posted February 29, 2016 i hang 10lb weights from my key ring. i have problems putting that back in to my pocket though. You too? I keep my spare set of cylinder heads on my key ring so when I'm at the track, I have them If I need them. Link to comment Share on other sites More sharing options...
bluesuby Posted February 29, 2016 Share Posted February 29, 2016 You too? I keep my spare set of cylinder heads on my key ring so when I'm at the track, I have them If I need them. Once you get them back in your pocket the ladies are impressed. Link to comment Share on other sites More sharing options...
GTEASER Posted February 29, 2016 Share Posted February 29, 2016 I had an 98 Accord that this happened to. The car just started shutting off randomly while driving. Once I figured it out, I changed out the ignition switch and put my 2 car keys on a different key ring than my house, parents house, office keys. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
chrystekaib Posted January 18, 2022 Share Posted January 18, 2022 (edited) A large bunch of keys will eventually loosen the ignition lock. The load from the keys looks ridiculous, but day by day, year by year, it loosens the knot, which was not initially designed for such kilograms. At first, the lock will stop "giving" the key; you will have to repeat the operation of pulling out, flicking the "mass" several times. Unfortunately, I also had such a problem. To solve it, I turned to Online Locksmith. I was consulted, explained the process of fixing; online, I want you to want it was cheaper. And I had a little variety in my work; thanks to the master was able to personally fix the lock. Edited January 19, 2022 by chrystekaib Link to comment Share on other sites More sharing options...
JMack Posted January 18, 2022 Share Posted January 18, 2022 I just carry a D-ring. Separate key rings for each vehicle and take off the appropriate one that I am driving and leave the rest attached to my belt loop. Been working for me for 6+ years now. Link to comment Share on other sites More sharing options...
Pleides Posted January 19, 2022 Share Posted January 19, 2022 What a thread to bump! I've heard of this folklore but I don't think most cars suffer from this issue, and I think it depends on the mounting angle of the ignition. Who knows, but I have a landyard full of key rings and stuff (gotta have a bottle opener handy when you're not at home!) and I've never ruined the ignition in my three old cars I've owned. Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 19, 2022 Share Posted January 19, 2022 I have one key, and a FOB. that is it. Garage door gets me in and out of the house. I have a key in my car that will get me in the side door if the power goes out and the garage doors will not open. Link to comment Share on other sites More sharing options...
Code Posted January 19, 2022 Share Posted January 19, 2022 What a thread to bump! I've heard of this folklore but I don't think most cars suffer from this issue, and I think it depends on the mounting angle of the ignition. Who knows, but I have a landyard full of key rings and stuff (gotta have a bottle opener handy when you're not at home!) and I've never ruined the ignition in my three old cars I've owned. Seatbelts make great bottle openers. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Pleides Posted January 19, 2022 Share Posted January 19, 2022 Seatbelts make great bottle openers. Gee, no wonder they put them there then! Link to comment Share on other sites More sharing options...
