blacksus Posted June 7, 2011 Share Posted June 7, 2011 hey guys i bought this transmission mount because it was advertised as fitting all 1999 subaru legacy's. i have a 1999 sus AT: http://i173.photobucket.com/albums/w69/cyang1/uqvm9a59.jpg this is what the one that came off my car looked liked: http://i173.photobucket.com/albums/w69/cyang1/3y3m6r4z.jpg my question is does that forth stud matter? the reason i ask is because i was a noob and bought the mount, and when i went to remove my old one i found out it had four studs instead of three. it looks like the fourth stud doesn't do anything. so would i get away with using the three stud mount? also everything fits perfect with the three stud. Link to comment Share on other sites More sharing options...
DN1911 Posted June 7, 2011 Share Posted June 7, 2011 should be fine... Link to comment Share on other sites More sharing options...
xero287 Posted June 7, 2011 Share Posted June 7, 2011 Looks like the mounting holes are different... Link to comment Share on other sites More sharing options...
blacksus Posted June 7, 2011 Author Share Posted June 7, 2011 the holes are the same, everything lines up. its just that i don't know if having that fourth stud is strength issue or not. Link to comment Share on other sites More sharing options...
DN1911 Posted June 8, 2011 Share Posted June 8, 2011 the stock mount has an extra stud, but the aftermarket shares the same pattern minus the one bolt. if it fit, don't worry bout it Link to comment Share on other sites More sharing options...
blacksus Posted June 8, 2011 Author Share Posted June 8, 2011 ok, thanks. i was just worried it would be a strength issue. Link to comment Share on other sites More sharing options...
