John Zimmerman Posted April 2, 2011 Share Posted April 2, 2011 My son's 98 Legacy L has flashers staying on all the time when the flasher button is not engaged.We disconnect the battery soas not to run down the battery but that does not reset anything.Any suggestions ? Thanks. Link to comment Share on other sites More sharing options...
subikid90 Posted April 2, 2011 Share Posted April 2, 2011 You need to put the key in the ignition and turn it all the way on then connect the battery. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
johnegg Posted April 2, 2011 Share Posted April 2, 2011 +1 what he said. the car has an alarm and the battery disconnect has triggered it. or you can try turning the key on and off 5 or 6 times really fast. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted April 2, 2011 Share Posted April 2, 2011 i was so puzzled by this the first time it happened to me. my old legacy didnt have keyless entry. now this one has that and a after market remote starter that i cant even use. Link to comment Share on other sites More sharing options...
kushmastercain Posted April 2, 2011 Share Posted April 2, 2011 their is a button under the steering wheel up above the pedals where all the wiring is the button is over toward the left. its kinda hard to find button if u have never used it. u have to hold the button and u have to have the key turned on. the flashers will do that everytime u dissconect and reconect the battery Link to comment Share on other sites More sharing options...
John Zimmerman Posted April 4, 2011 Author Share Posted April 4, 2011 Problem solved. With battery connected,use the remote door lock/unlock. This will reset things and the flashing stops. Any time the battery is disconnected you must do this. my car does not have an alarm system. this advice came from my local Subaru dealership service dept. Link to comment Share on other sites More sharing options...
johnegg Posted April 4, 2011 Share Posted April 4, 2011 the alarm and the remote door lock are the same unit. they just add an extra wiring pigtail and a siren if the customer wants alarm. the other solutions should work as well. which is good to know if you buy a used subaru with no remote like i did, twice. Link to comment Share on other sites More sharing options...
Schnayke Posted April 4, 2011 Share Posted April 4, 2011 If you got your car used, how would you tell if it had remote door locks? I have electric locks I think I may have remote door locks but am unsure. second question is how would you get another remote? Link to comment Share on other sites More sharing options...
johnegg Posted April 4, 2011 Share Posted April 4, 2011 if it is a subaru install, it may have a yellow sticker under the hood on the radiator support . or you get on you knees and look up under the dash to see if the black unit it there. or disconnect the battery for 10 minutes and reconnect it. if the lights flash then you have remote entry or alarm. you can probably get a remote on ebay or the dealer. Link to comment Share on other sites More sharing options...
