RooTBeeR Posted August 2, 2014 Share Posted August 2, 2014 Back Story. I have a 2005 LGT 5EAT, Bone Stock. Thanksgiving 2013 I took it out to the desert to play a bit. All was fine and dandy until I went for a top speed run on my way back to camp to park it. Got up to 115mph, noticed it stopped accelerating, and was going to back out a bit. Before I got a chance to, CEL came on. “Cylinder 1 Misfire”. Coasted down for about 1/2 mile, stopped. As it came to idle, heard a knock. Turned it off and back on, CEL was gone, ran fine even, just had a loud knock. Ended up driving it about 160miles with the knock to get it home. http://youtu.be/APQzZvUBPu4 Tore it apart and found out that #2 has a bit less piston than it was installed with. #2 Looks like it was part of my oil consumption issue. #2 and #4 Journals and intake cam are scored. #1 and #3 had some scoring on the exhaust cam and journals too. Just didn’t bother with pics. #2 Top #2 Bottom #3 Top #3 Bottom Yet, #4 the typical trouble maker, looks normal. New Build Short Block = $1,340 Used 12,000 mile OEM 2013 STI 257 Short Block. The previous owner made one dyno run up to 470whp 420wtq @21psi on E85. He ran it on 19psi making 420whp 380wtq to prevent damage. He’s only selling it to help fund a closed deck block and make more power. Heads = $722 Used D25 Bare Castings. I was originally going to get new “B” heads and 9:1 pistons because this is my daily driver and I spend a lot of time sitting at traffic signals(stop and go) and don’t get to boost much and wanted a little more off idle/boost power. Then I decided that it’s best for me to leave the short block as is, because it’s much cheaper than going through the whole bottom end and taking it to a machine shop and then buying pistons on top of all of that. So I decided to go with “D” heads that will give me an 8.7:1 CR and that’s close enough for me and is far more budget friendly. Higher than it was, and yet still low enough not to give me any “on boost” problems with the Cali Cat Piss 91. Cams = $200 Used 80,000 mile OEM 2005 STI Cams Valves, Springs, Retainers, Locks = $0 Reusing my original parts. Turbo = $0 No shaft play or oil leaks on my stocker, so just reinstalling it as is. Intake Valve Seals = $44 Exhaust Valve Seals = $51 OEM Gasket Kit = $265 12mm OEM Oil Pump = $195 Gates Timing Belt Kit w/ Water = $265 OEM Spark Plugs = $53 BMB’s Bullet Proof TIMC Kit = $90.00 Dyno Tune = $700 Adding to this list as I go. Red parts I still need. First part I bought since it's the first part I broke while removing the engine. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 2, 2014 Author Share Posted August 2, 2014 Saved for future stupidity. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 2, 2014 Author Share Posted August 2, 2014 Yes, also this one. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
BoozeRS05 Posted August 2, 2014 Share Posted August 2, 2014 Always a fan of disassembled motor pics.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
