RustyShackleford Posted April 13, 2015 Share Posted April 13, 2015 I faithfully bleed/replace my brake fluid every year or two - a task made much easier by speedbleeders (one way valves that replace the regular bleeder valves on the slave brake cyclinders). I was wondering if people ever worry about doing the same thing to the clutch hydraulic system ? Link to comment Share on other sites More sharing options...
GTEASER Posted April 13, 2015 Share Posted April 13, 2015 You could bleed your clutch and may possibly get better feel but I doubt it would be noticeable. The clutch fluid doesn't see the same heat that the brake fluid does in the calipers. I usually just wait until I need a clutch replaced or some other item in the clutch hydraulics need servicing. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
RustyShackleford Posted April 13, 2015 Author Share Posted April 13, 2015 I didn't really think it'd help the feel. Just that it'd be a good and simple preventative measure. I believe the idea of changing brake fluid is that it absorbs water, which causes rust in the system. Link to comment Share on other sites More sharing options...
GTEASER Posted April 13, 2015 Share Posted April 13, 2015 I didn't really think it'd help the feel. Just that it'd be a good and simple preventative measure. I believe the idea of changing brake fluid is that it absorbs water, which causes rust in the system. The water causing rust is not the main concern, the bigger thing is it decreases the hydraulic fluids capacity to hold pressure. Repeated heat cycles and boiling of the brake fluid from overheating is what invites moisture into the braking system. You don't get that same intense heat in the clutch hydraulics. If you want to do it, do it for piece of mind. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
RustyShackleford Posted April 14, 2015 Author Share Posted April 14, 2015 Thanks guys, I think you've convinced me that I'm being silly. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 15, 2015 Share Posted April 15, 2015 ...or to get the bubbles out of the clutch system. Link to comment Share on other sites More sharing options...
