rs6er Posted April 4, 2014 Share Posted April 4, 2014 I have an exhaust leak between my stock down pipe and Borla cutback. Which gasket do I need, does brand or material matter, and will I need to replace the bolts? Are there springs there also? I live in a very rust prone place. I'd get under the car, but it's raining at the moment. I don't want to start the repair and find I need more than just the gasket. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 4, 2014 Moderators Share Posted April 4, 2014 Stock downpipe is 2.5" at the exit. The borla is also 2.5" at the downpipe connection, correct? If so, you'll want a fresh donut gasket. If you deal with rust issues, not the worst idea to replace the hardware there as well--spring bolts and nuts. Pretty sure I have a set of bolts and a donut gasket for you if you're interested. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
rs6er Posted April 4, 2014 Author Share Posted April 4, 2014 Correct about the 2.5 for Borla. Is your gasket new? Link to comment Share on other sites More sharing options...
rs6er Posted April 8, 2014 Author Share Posted April 8, 2014 Where can I find the numbers for those parts? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 8, 2014 Moderators Share Posted April 8, 2014 Sorry, missed this. No, gaskets aren't new but I typically have a smattering of donut gaskets in good condition lying around. Spring bolts may be claimed for an install I'm doing this weekend, but the dealer should be able to set you up with a pair. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
