Legacy05GT Posted November 24, 2004 Share Posted November 24, 2004 I purchased the STi Trunk Lip Spoiler from kingofimports.com. Here is what i recieved. Obsidion Black spoiler, 4 nuts, 2 plastic nub things, 1 zip ties, 1 black sticker(for existing 3rd brake light), paper template(japanese), and installation iinstructions(japanese) Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 First I had to peel back the lining of the trunk so i would have access to the underside and so i can locate the brake light plug for testing The "Auxilary" brake light plug was easily found (using the Tear-down manual, thanks Jedi). Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 Since i did this on my own, i had to wedge a brush between the drivers seat and the brake pedal. The brake light worked fine and i was able to move on. Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 This paper template had to be positioned perfectly so that spoiler would be straight. Unfortunatly all measurement details were in japanese, the only number that i had to work will was 200MM, which i'm assuming is supposed to be the distance from the edge of the trunk. That would be easy except for the fact that there was no straight edge or line to reference by. Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 Using some high-school math, i was able to tape out a perfect rectangle for refrence. I marked out the posision of the holes after i matched up the template. Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 After measuring and re-measuring about 50 times, i drilled the first holes using a 1/8" bit. Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 This was followed by stepping up the bit size until i could easily mock-fit the spoiler on the trunk. Holes were drilled for the 4 bolts, 2 plastic nubs, and brake wiring.(The plastic nubs were later removed and the holes were filled from the inside with plummers putty). Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 Heres the match=up of the holes to the bolts. The brake light wiring was fed through a center hole. I put a little dab of plummers putty on each bolt to prevent leaking(if it rains, etc). Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 The results. Link to comment Share on other sites More sharing options...
Legacy05GT Posted November 24, 2004 Author Share Posted November 24, 2004 And i thought this was a cool pic w/ LegacyGT.Com, SymmetricalAWD, STi, and the subaru emblem. Link to comment Share on other sites More sharing options...
axis008 Posted November 24, 2004 Share Posted November 24, 2004 Let me be the first to say SWEET! I can't wait to get that spoiler for my currently-non-existant car. Must be scary drilling holes into your trunk. I wonder what someone would to do fix it. Bondo? -ben Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted November 24, 2004 Share Posted November 24, 2004 Looks great. Ain't it some scary sh!t drilling into your car. hehe OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
maosta Posted November 26, 2004 Share Posted November 26, 2004 the spoiler looks great. Thumbs Up :D That's a damn good sugar cookie. Link to comment Share on other sites More sharing options...
agctr Posted November 26, 2004 Share Posted November 26, 2004 You da Man, well done and thanks for taking the time to post pics. Certainly looks great and have to agree with Boxer, that it would be a little scary posting holes anywhere on your car. Looks great..... Adam. Link to comment Share on other sites More sharing options...
minh Posted December 17, 2004 Share Posted December 17, 2004 very nice. how did you get the sticker for the third brake light in there? can you also unplug it too? Link to comment Share on other sites More sharing options...
KevinSoD Posted December 18, 2004 Share Posted December 18, 2004 this is a must! quonto questa? Link to comment Share on other sites More sharing options...
Legacy05GT Posted December 19, 2004 Author Share Posted December 19, 2004 $600-$650. Pero creo que lo valió Link to comment Share on other sites More sharing options...
red beast Posted December 19, 2004 Share Posted December 19, 2004 did you put primer around the new holes so they won't rust? Link to comment Share on other sites More sharing options...
meier motor sports Posted December 19, 2004 Share Posted December 19, 2004 u have some balls drilling into a new car! yikes! but looks great. congrats Link to comment Share on other sites More sharing options...
Legacy05GT Posted December 19, 2004 Author Share Posted December 19, 2004 [quote name='red beast']did you put primer around the new holes so they won't rust?[/QUOTE] nope... but i did use plumbers putty on each hole. Aslong as it keeps it watertight, there should be no rust. [quote name='meier motor sports']u have some balls[/QUOTE] yes...i indeed have balls Link to comment Share on other sites More sharing options...
Leonardo Posted May 4, 2005 Share Posted May 4, 2005 great write up! Now, I just need to get one and re-paint it red! Te quedo bien bueno el escrito! Link to comment Share on other sites More sharing options...
kevinkingofimports.com Posted June 24, 2005 Share Posted June 24, 2005 1 left in stock if anyone is looking for one. Its the standard flat sti black. Subie.tv Link to comment Share on other sites More sharing options...
Leonardo Posted June 24, 2005 Share Posted June 24, 2005 $? Link to comment Share on other sites More sharing options...
fbi012 Posted June 24, 2005 Share Posted June 24, 2005 ya $? Link to comment Share on other sites More sharing options...
carcand Posted September 14, 2005 Share Posted September 14, 2005 first one i've seen with a third brake light on it. Link to comment Share on other sites More sharing options...
