JustDrew Posted January 6, 2011 Share Posted January 6, 2011 Hey everyone, I just bought my 2006 Legacy 2.5i Limited a couple weeks ago. I'm looking to replace all 4 door speakers. I had my heart set on the Polk Audio db651's but I called Polk to see if they'd fit and they claimed that they wouldn't. Polk claimed that the speaker would hit the door panel. I found this odd because I recall seeing a DiY thread on this forum that specifically put the db651's in the rear door, at the very least. I'm not trying to do many alterations as I'm very much a beginner at this. I need 4 new door speakers that sound good and have a solid low end. I'm not looking to win any bass competitions but I do like a good thump like the next guy. What are your suggestions? Oh, I've also considered putting an AMP on the doors once I replace them because I don't really want to replace the HU but I want to get the most out of the speakers as I can. I just want something to bump w/o having to go the route of the bigger subwoofer in the trunk and the rear deck sub install (pre cut hole) looked a little overwhelming to me. Your feedback is greatly appreciated as I'm beginning to feel at a loss. -JustDrew Link to comment Share on other sites More sharing options...
proflatlander15 Posted January 6, 2011 Share Posted January 6, 2011 I actually just put in some Polk DB651s in my rear doors and they fit fine. I did however use the OEM plastic bracket/speaker to mount them. I basically ripped the OEM speaker out of the plastic case, and screwed the Polks to the case and mounted them from there. Worked great; and they sound fine too. I am in the process of hooking them up to an amp but I screwed up some wiring and haven't got it all hooked up yet. This weekend I should finish. Link to comment Share on other sites More sharing options...
exsterminator Posted January 6, 2011 Share Posted January 6, 2011 I was recommended the 651s for the front doors (s for slim profile I believe) and the regular ones for the rears. Have purchased them but not installed as yet Link to comment Share on other sites More sharing options...
JustDrew Posted January 7, 2011 Author Share Posted January 7, 2011 I was recommended the 651s for the front doors (s for slim profile I believe) and the regular ones for the rears. Have purchased them but not installed as yet I was just concerned about the db651s because I'm worried about losing some of the low end bass. I suppose it's probably better then the factory ones in there now. I just don't want to have to do it twice if I'm not happy. Link to comment Share on other sites More sharing options...
JustDrew Posted January 7, 2011 Author Share Posted January 7, 2011 I actually just put in some Polk DB651s in my rear doors and they fit fine. I did however use the OEM plastic bracket/speaker to mount them. I basically ripped the OEM speaker out of the plastic case, and screwed the Polks to the case and mounted them from there. Worked great; and they sound fine too. I am in the process of hooking them up to an amp but I screwed up some wiring and haven't got it all hooked up yet. This weekend I should finish. No vibration? Did you do and sound deadening? Link to comment Share on other sites More sharing options...
proflatlander15 Posted January 7, 2011 Share Posted January 7, 2011 No vibration. I wedged the foam gasket between the speaker and the OEM housing. I did not do sound deadening, I don't have the funds right now. I would like to in the future, however. Link to comment Share on other sites More sharing options...
JustDrew Posted January 18, 2011 Author Share Posted January 18, 2011 I'm getting ready to put the db651s in the front and the regular db651 in the rear and a KAC-6404 amp. I'm doing it Thursday night. Link to comment Share on other sites More sharing options...
proflatlander15 Posted January 18, 2011 Share Posted January 18, 2011 Awesome. I finished my install last weekend and they sound great. Running them off an amp is beautiful. Link to comment Share on other sites More sharing options...
Phila Posted January 24, 2011 Share Posted January 24, 2011 Awesome. I finished my install last weekend and they sound great. Running them off an amp is beautiful. Did you take the whole door panel off to install the speakers or do the speaker grills pop off so you don't have to take the entire panel off? Link to comment Share on other sites More sharing options...
proflatlander15 Posted January 24, 2011 Share Posted January 24, 2011 You have to take off the entire panel. There is a great tutorial on here in the audio forum on how to remove them. Three screws, and a bunch of those cheap plastic poppet things. Link to comment Share on other sites More sharing options...
JustDrew Posted January 25, 2011 Author Share Posted January 25, 2011 yeah...gotta remove the entire door. It's pretty easy and this REALLY helped... [ame=http://www.youtube.com/watch?v=v9vMJVp7gGE]YouTube - How to remove speakers from a 2005 Subaru Legacy/Outback[/ame] be warned....getting the cover off the door handle is not as easy as the guy makes it look but it will come off with some effort, especially if it's the first time like mine was. I tried to run mine off an amp but the one I got was no good and had to send it back. (defective RCA jack) Now I have them running off the factory head unit and they still sound great. I actually have to fade them to the rear (rear 3 or 4 depending) and put the treble at -2 because they sound so good. I do have the bass at +3 or +4 but that will change because I'm getting a preamp Sound Ordnance 8" sub in a bandpass box to get some deeper/richer lows. after that I'm all done. All the wires have been ran....just waiting for it to show up. I can't wait!! Link to comment Share on other sites More sharing options...
OhBe1 Posted January 25, 2011 Share Posted January 25, 2011 rear: http://legacygt.com/forums/showthread.php/2006-legacy-rear-door-speaker-installation-diy-96930.html?t=96930&highlight=db651 front: http://legacygt.com/forums/showthread.php/2006-legacy-front-door-speaker-installation-diy-96931.html?p=2471113#post2471113 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Phila Posted January 26, 2011 Share Posted January 26, 2011 To install the db651/db651s do you just have to cut the connector off and reconnect the wires to the new speakers? There's no crossover or anything else involved, or is there? Link to comment Share on other sites More sharing options...
JustDrew Posted January 27, 2011 Author Share Posted January 27, 2011 To install the db651/db651s do you just have to cut the connector off and reconnect the wires to the new speakers? There's no crossover or anything else involved, or is there? Yes, that's what we did...Just cut off the factory connector. I've had the speakers in since last thursday and they're really starting to come alive. I can't wait to get my sound ordnance 8" preamped sub....I think it'll be the perfect sound combo and complete my audio. Link to comment Share on other sites More sharing options...
GTS Jeff Posted January 27, 2011 Share Posted January 27, 2011 http://www.iaperformance.com/index.php?cPath=44_63_64_65 Link to comment Share on other sites More sharing options...
MiniStiGuy Posted January 28, 2011 Share Posted January 28, 2011 What you need is an 07 or 08 radio as they have the SRS EQ and really bring out more low end and crisp up the highs as well. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
JustDrew Posted February 17, 2011 Author Share Posted February 17, 2011 I'm finally finished. it wasn't w/o it's bumps in the road....no pun intended but here is the last of my "budgeted" adds... Sound Ordnance 8" powered sub. Takes up small space but has a great punch and will even rumble on the very low's. I thrilled with it. Great compliment to the new Polk door speakers. http://i195.photobucket.com/albums/z255/whowillgo/Subaru/Subphoto.jpg Link to comment Share on other sites More sharing options...
