upping the mpg?
Yaz
what's your current MPG?
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
Even with no tune on exhaust mods, you could see an improvement.
There is a chance you will see an improvement w/ the intake also w/ no tune, but if you do, it will be because you are running lean. Which means your engine could go boom ;)
Overall, anything that gives the engine more power (other than a turbo) is actually making it more efficient. So drven EXACTLY the same way, mpgs will go up.
The difference w/ the turbo is that the size effects how often the car is in boost. The more you are in boost, the more fuel you use ;)
:spin:
thanks for the help guys, gives me some stuff to think about... i'm avg 17 - 18mpg but all of my driving is city so I expected it to be a little low.
Better than me. I barely see the freeway unless i'm to or from jersey.
