gimpydingo Posted March 3, 2015 Share Posted March 3, 2015 I am going to be replacing the front and rear sb bushings. Looks like the stock front is 21mm and rear is 16mm. I am trying to find either AVO or Whiteline, since those seem to fit the stock brackets and are a stronger/stiffer material. I know there are the energy bushings, but would rather not deal with their brackets. Any assistance? Link to comment Share on other sites More sharing options...
whitetiger Posted March 5, 2015 Share Posted March 5, 2015 the ES bushings have amazing brackets. id go for those. you wont be sorry. the stock brackets are weak. Also the ES bushings are better than any other aftermarket version. Some even come with grease fittings. it really is a no-brainer. Link to comment Share on other sites More sharing options...
gimpydingo Posted March 5, 2015 Author Share Posted March 5, 2015 I just ordered some right before you posted. 20.5mm greaseable (21mm wasn't greasable) for the front and 16mm greasable for the rear. Any suggestions on type/brand of grease I should use on these? $200 in parts coming over the next week, can't wait to dig in! Link to comment Share on other sites More sharing options...
whitetiger Posted March 5, 2015 Share Posted March 5, 2015 they should come with some starter grease. any bushing grease meant for silicone bushings should be fine. Link to comment Share on other sites More sharing options...
gimpydingo Posted March 5, 2015 Author Share Posted March 5, 2015 The order didn't say it came with grease, figured it would, but just in case. Thanks! Link to comment Share on other sites More sharing options...
Myevodream Posted April 6, 2015 Share Posted April 6, 2015 So stupid question, and dont mean to hijack OP's thread, but it's kind of related. I'm actually replacing my 08 lgt rear sway bar bushings (and presumably brackets as well). Stock rear size seems to be 16mm as what I have researched as well, but where can I find stock rear sway bushing replacements, in polyurethane? The ES site doesnt seem to show rears for my car? And all the others I saw look to be 20mm including whiteline which would not fit my stock sway.... And endlinks while we're at it, for stock sway bar...anything out there? Link to comment Share on other sites More sharing options...
whitetiger Posted April 6, 2015 Share Posted April 6, 2015 on the ES site, you will want to go the universal bushing section. it wont be model specific. Link to comment Share on other sites More sharing options...
whitetiger Posted April 6, 2015 Share Posted April 6, 2015 here if you are lazy - http://www.energysuspensionparts.com/Universal-Sway-Bar-Bushings.asp Link to comment Share on other sites More sharing options...
Max Capacity Posted April 6, 2015 Share Posted April 6, 2015 Or just PM "underdog" and ask him what to use and buy from him. That's what I did. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted April 6, 2015 Author Share Posted April 6, 2015 To update, got them installed, not too much trouble. The front braces I cut down to fit. Everything is holding tight, feels much better. Link to comment Share on other sites More sharing options...
whitetiger Posted April 7, 2015 Share Posted April 7, 2015 the stock u-clamps for the sway bar bushings are straight garbage. the ES ones are so much better and make everything much more secure. Link to comment Share on other sites More sharing options...
