jeguzik Posted May 9, 2008 Share Posted May 9, 2008 What is a good spring to go with the Spec.b setup. I am looking for a little less body roll, but not losing to much in terms of comfort. What is the best value in the market. Also, what is a good upgrade to the rotors and pads for better brake performance. Once the OEM stuff is shot I would like to upgrade? Link to comment Share on other sites More sharing options...
fweasel Posted May 9, 2008 Share Posted May 9, 2008 Myles from Racecomp Engineering was a big fan of the Pinks on his SpecB I'm a fan of the Hawk HPS pad for street use. I run them on all three of my cars. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
magnetic1 Posted May 9, 2008 Share Posted May 9, 2008 We've got blank, slotted and slotted/x-drilled rotor replacements for stock on sale now! Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Drew888 Posted May 10, 2008 Share Posted May 10, 2008 Jeguzik, If I'm reading into your post right, you are not that aggressive of a driver and are looking for a minor upgrade. For you, Cobb or Whiteline swaybars both front and rear, Bobcat or HPS pads and you will be pleasantly surprised. This will allow you to keep all of the comfort you have now without any loss while reducing the floatiness (SP) of the OEM suspension. Now every step up from there improves on the handling and unlike many cars out there doesn't really add all that much NVH. Go test drive a new/used BMW M3. The additional harshness compared to the LGT is exactly what you'll expect when going to something like a Tarmac I coilover (on full soft). Doing so really raises the bar on overall grip and feedback. It all depends on how far you would like to go and how you use/drive your car. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
jeguzik Posted May 11, 2008 Author Share Posted May 11, 2008 Jeguzik, If I'm reading into your post right, you are not that aggressive of a driver and are looking for a minor upgrade. For you, Cobb or Whiteline swaybars both front and rear, Bobcat or HPS pads and you will be pleasantly surprised. This will allow you to keep all of the comfort you have now without any loss while reducing the floatiness (SP) of the OEM suspension. Now every step up from there improves on the handling and unlike many cars out there doesn't really add all that much NVH. Go test drive a new/used BMW M3. The additional harshness compared to the LGT is exactly what you'll expect when going to something like a Tarmac I coilover (on full soft). Doing so really raises the bar on overall grip and feedback. It all depends on how far you would like to go and how you use/drive your car. I will never track my car, but I would like to tighten down the handling a bit. I am looking for a little more like an M3 handling, comfortable, but sporting. Right now I am just comfortable, there is just to much front to rear dip under accelleration and braking, and toooo much roll into the corners. She handles, but not as well as I would like. Thanks, J Link to comment Share on other sites More sharing options...
