Lego3410 Posted May 2, 2014 Share Posted May 2, 2014 Hey I am having a problem with my automatic stock 2010 legacy 2.5i. When I slam on the brakes the car stalls out on me. And when I come stop a shuttle stop it will bogg down but not stall out.I don't throw a check engine light and I sea foam it every other oil change. And yes I put the sea foam in the gas tank, vacuum line from the brake booster, and where you add the oil. The car has 135,000 miles on it and I haven't changed the spark plugs. But I don't think that's the problem since I'm not miss firing and throwing a check engine light. Any suggestions? I'm all ears.. Thanks, Lego3410 Link to comment Share on other sites More sharing options...
bomberlegacy Posted May 2, 2014 Share Posted May 2, 2014 Sorry I can't offer any other advice..but you should change your plugs anyway...age plus the sea foam can eat them up.. Probably not the problem and I'm sure others can chime in but plugs are easy and cheap.. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
Lego3410 Posted May 2, 2014 Author Share Posted May 2, 2014 Thanks yeah I do intend on replacing them just because of the mileage. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 4, 2014 Share Posted May 4, 2014 136k on one set of plugs is excessive. Start there and pull the code when it shows up next time, it should still be present if you havent reset the ECU. That will tell us a decent amount of info Link to comment Share on other sites More sharing options...
orndog Posted May 4, 2014 Share Posted May 4, 2014 Could be things like weak fuel pump or weak vacuum. Check the hose you've been pouring that seafoam into. Also, using seafoam that often your plugs might be sparkly clean and beyond worn out. Link to comment Share on other sites More sharing options...
Lego3410 Posted May 4, 2014 Author Share Posted May 4, 2014 Plugs it is. I will take care of them next the nest day or two. I don't throw a CEL but when and if I do next time I agree that it will give me a better idea as to where the problem is. Thank you everyone I will post an update as soon as I can. Link to comment Share on other sites More sharing options...
Jay12Legacy Posted May 8, 2014 Share Posted May 8, 2014 if its a cvt poss torque converter not unlocking Jay Link to comment Share on other sites More sharing options...
Lego3410 Posted May 23, 2014 Author Share Posted May 23, 2014 Ok so I did change the park plugs and that wasn't the problem. Although they still needed changing. Link to comment Share on other sites More sharing options...
apexi Posted May 23, 2014 Share Posted May 23, 2014 I did some research on this, and unfortunately it's likely your torque converter is bad. It sounds like subaru knows about this issue, and they redesigned the torque converter as a result. Out of curiosity I looked up how much a new torque converter costs, MSRP is $675, with online subaru parts dealers offering it for around $550. Service Bulletin # 16-90-13 Design Change to Lock-Up Type Torque Converter Torque Converter Bulletin Description: This bulletin announces the availability of a countermeasure torque converter assembly to address a customer concern of very low engine RPM when coming to a stop. The condition is similar to coming to a stop in a manual transmission equipped vehicle without depressing the clutch pedal. Thrust washer wear inside the torque converter torque converter can cause restriction of the oil passage used to bleed off lock-up clutch application pressure. The result is either a delayed (momentary low engine rpm) or no lock-up pressure release. The thrust washer has been changed from a solid bushing-type to a needle bearing type. Link to comment Share on other sites More sharing options...
Lego3410 Posted May 24, 2014 Author Share Posted May 24, 2014 Unfortunately it does sound like my problem. Now the question is do I want to tackle this myself or not. I've done transmission swaps in my bugeye years ago but that's been awhile. And should I replace it wih a Stronger torque converter while I'm at it? I was up half the night researching if I have a 4eat or 5eat? Maybe I wasn't looking in the right places.? Link to comment Share on other sites More sharing options...
apexi Posted May 24, 2014 Share Posted May 24, 2014 It looks like the 2010 2.5i's should have a CVT, not a 4eat or 5eat. Link to comment Share on other sites More sharing options...
Holygow Posted August 30, 2014 Share Posted August 30, 2014 So was it the torque converter? Im having the same issue with my 2011 legacy cvt. How much did that cost to replace with labor? Link to comment Share on other sites More sharing options...
Lego3410 Posted September 3, 2014 Author Share Posted September 3, 2014 No I have not replaced it yet Subaru gave me a estimate of ab 1100.00 but I've replace transmissions before on my 03 wrx! So I'd hate to pay Subaru when I could do it my self. The torque converter is ab 650 or so just for the part. With what research I have done it seems that it is the torque converter but still not 100%. Link to comment Share on other sites More sharing options...
scott6058 Posted October 12, 2014 Share Posted October 12, 2014 My 2011 Legacy is at the dealer having just this done. Subaru also claims this isn't an absolute fix as sometimes the valve body needsreplaced as well. I'll get back with the results and cost very soon if interested. By the way my Subbie started with these symptoms at 70K not far after the warrentee expired. Best luck Scott Link to comment Share on other sites More sharing options...
Lego3410 Posted October 13, 2014 Author Share Posted October 13, 2014 My 2010 started showing signs of it going to stall out early as well. Didn't think to much of it at the time. I mentioned it to Subaru but they just scratched their heads and check the throttle body to see I it was gummed up. Needles to say that wasn't the case. Please let me know ab how much they are going to charge you and what actually is the problem. Thanks Charles Link to comment Share on other sites More sharing options...
scott6058 Posted October 13, 2014 Share Posted October 13, 2014 Sure will Charles. My Legacy is easy to aggregate the situation. Just come to an abrupt stop. It will stall every time. Hope this helps others.. Scott Link to comment Share on other sites More sharing options...
Lego3410 Posted November 13, 2014 Author Share Posted November 13, 2014 Hey Scott what turned out to be the problem? And how much was it? Link to comment Share on other sites More sharing options...
scott6058 Posted November 14, 2014 Share Posted November 14, 2014 http://i1252.photobucket.com/albums/...sce5745c0.jpeg Link to comment Share on other sites More sharing options...
apexi Posted November 14, 2014 Share Posted November 14, 2014 Link doesn't work. I think this might be what was supposed to be in the above link http://i1252.photobucket.com/albums/hh578/scott6058/Scan1_zpsce5745c0.jpeg Link to comment Share on other sites More sharing options...
jpotts Posted November 19, 2015 Share Posted November 19, 2015 Click the link. I just had the same thing happen to my Legacy 2012 w/ 76216mi Crossposting another torque converter issue Link to comment Share on other sites More sharing options...
apexi Posted November 19, 2015 Share Posted November 19, 2015 Good to hear Subaru took care of you under warranty jpotts Link to comment Share on other sites More sharing options...
