Inspector Gadget Posted October 23, 2014 Share Posted October 23, 2014 I had smelled burning oil earlier in the day, so when I pulled in the driveway and saw a little smoke billow out of the hood scoop I knew I had a problem. I have leaks/oil weeping from the oil pan, oil cooler seal (?), right valve cover gasket, one of the head gaskets and the transmission shift shaft seal. I'm going to have head gaskets replaced and a valve job done while the motor is apart. The shop will take care of all the other issues while they're at it as well as installing my new, ceramic coated up and down pipes. Since they will have my car for a week, I am also going to have them install my new Koni/H&R Springs set up. I am sure as hell not excited about the price tag! But I am really excited about the finished product! Link to comment Share on other sites More sharing options...
optyks Posted October 23, 2014 Share Posted October 23, 2014 Hell yeah! I say we have a meet after you get that done and after I get all my stage 3 bits up and running well. Seems to be project season! My build in the next couple weeks is: Forced Performance HTA68 Power Enterprise 850cc injectors Deatchworks 65c pump Innovate Motorsports wideband gauge kit Spark plugs of some sort. And a tune by Logan when it's done Link to comment Share on other sites More sharing options...
Inspector Gadget Posted October 23, 2014 Author Share Posted October 23, 2014 Oh, yeah, I also need to install my new slotted rotors, brake pads and stainless lines. Cha-ching! Link to comment Share on other sites More sharing options...
Inspector Gadget Posted October 24, 2014 Author Share Posted October 24, 2014 The turbo is toast, so I have a low mileage VF46 on its way. The throw-out bearing is also garbage. But I did find my light-weight Cobb crank pulley when I was going through my parts, so that will finally get installed. Ruby isn't looking her best. Link to comment Share on other sites More sharing options...
Blue Shark Posted October 25, 2014 Share Posted October 25, 2014 Your car is probably going to feel a lot better with all of that lol. Link to comment Share on other sites More sharing options...
Inspector Gadget Posted October 26, 2014 Author Share Posted October 26, 2014 I spent yesterday morning assembling the Koni Sport Kit that is going on the car while she's in the shop. I may not recognize my car when I get it back. Link to comment Share on other sites More sharing options...
optyks Posted October 26, 2014 Share Posted October 26, 2014 So a shop is doing your engine stuff? Was gonna say, damn you are confident. Link to comment Share on other sites More sharing options...
Inspector Gadget Posted October 27, 2014 Author Share Posted October 27, 2014 I spent my first couple years out of high school as a Porsche mechanic. I also built and raced Datsun 510s for about 10 years. I still have most of my tools and my neighbor has a lift and every other tool you could ask for; he's said I'm welcome to use his place whenever I need to. What I don't have is the time to do all the work that is needed. The shop that has the car specializes in Subarus; they have an excellent reputation and even offer a 3 year 36,000 mile warranty on their work. Which is more than I can say for most shops. Link to comment Share on other sites More sharing options...
optyks Posted October 27, 2014 Share Posted October 27, 2014 You should let me know the name of the shop. Here or via pm, whichever Link to comment Share on other sites More sharing options...
Inspector Gadget Posted October 27, 2014 Author Share Posted October 27, 2014 The shop is in Heber; let me know if you still want their info. Link to comment Share on other sites More sharing options...
LeGiT_Flat4 Posted October 28, 2014 Share Posted October 28, 2014 Sad to see her all torn apart but keep us posted on the progress. Your strut bodies/springs look amazing. Now I wish I would cleaned mine up and painted them but I ended up being too lazy. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 2, 2014 Share Posted November 2, 2014 Looks like you have a good project going here. While things are apart, have you checked the play in the front sway bar bushings ? I just replaced mine. Also check out the shifter stay bushings. I just bought my Cobb stay bushings from "underdog". If your using the LWCP make sure you stay with a steel SMFW. How are the heat shields on the exhaust manifold ? I cut the center one off while my tranny was out a few weeks back, I wrapped it with DEI heat wrap. No picture of it but in my click here link you can see other parts I DEI wrapped. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
