bmglaude Posted June 20, 2012 Share Posted June 20, 2012 Mods = Invidia catless DP, Magnaflow exhaust, VF52 Turbo, deatschwerks 65cc fuel pump, opensource tune. I had an oil change done and replaced my K&D drop-in airfilter with a paper filter because I was led to believe that the oils from the K&N may have contributed to my MAF going on me. As soon as I left the shop my car started struggling to stay going add low rpms and started stalling out on me when stopped, almost like my idle was to low. Anyone know what maybe going on? Link to comment Share on other sites More sharing options...
angeltalin Posted June 20, 2012 Share Posted June 20, 2012 Check all vacuum hoses StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
angeltalin Posted June 20, 2012 Share Posted June 20, 2012 Also check your endtanks on your intercooler StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
bmx045 Posted June 21, 2012 Share Posted June 21, 2012 reset ecu Link to comment Share on other sites More sharing options...
MrHellrais3R Posted June 21, 2012 Share Posted June 21, 2012 Sounds like a bad vac leak to me. i had that happen to me once when the pcv line popped off of my turbo inlet while I was driving. Either do a pressure test or you can have someone sit in the car while keeping the rpm high enough to not stall out and listen for that seeping air sound. Doing a visual wont always show if and where the leak it. If it is a leak then its a fairly large one due to it causing the car to stall out. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 21, 2012 Share Posted June 21, 2012 http://legacygt.com/forums/showthread.php/crazy-easy-vacuum-boost-leak-tool-187968.html Link to comment Share on other sites More sharing options...
charlie_sheen Posted June 21, 2012 Share Posted June 21, 2012 they reset the ecu at the shop, probably disconnected the battery. it'll be fine in week. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 21, 2012 Share Posted June 21, 2012 They might have wiggled the turbo inlet a bit and something there came loose. These turbo inlets are crap, I should have gone aftermarket a while ago. Link to comment Share on other sites More sharing options...
bmglaude Posted June 21, 2012 Author Share Posted June 21, 2012 How can I be sure if I have a vacuum leak or bad MAF? Link to comment Share on other sites More sharing options...
Nrw Posted June 21, 2012 Share Posted June 21, 2012 Boost leak tester, buy one or make one like MaSAyinde did http://legacygt.com/forums/showthread.php/crazy-easy-vacuum-boost-leak-tool-187968.html Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted June 21, 2012 Mega Users Share Posted June 21, 2012 Sounds like a bad vac leak to me. i had that happen to me once when the pcv line popped off of my turbo inlet while I was driving. Either do a pressure test or you can have someone sit in the car while keeping the rpm high enough to not stall out and listen for that seeping air sound. Doing a visual wont always show if and where the leak it. If it is a leak then its a fairly large one due to it causing the car to stall out. this. and if not this then clean MAF, if not that then reset ECU. Rought idle? Then check your TGVs. CEL? "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
20sti04 Posted June 21, 2012 Share Posted June 21, 2012 Try cleaning your intake filter and resetting your ecu? Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted June 21, 2012 Mega Users Share Posted June 21, 2012 whoa. wait a second. just had this happened to me. Make sure your airbox is completely sealed, especially since you just put a k and n in. Pop the hood and make sure the tabs are in place and there is a perfect seal on the box. If not, it will cause a rough idle, and the car to stall periodically at idle. Also p0171 "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
bmglaude Posted June 22, 2012 Author Share Posted June 22, 2012 I changed from a K&N to a stock paper filter. I was hoping the airbox was going to be the culprit but unfortunately it looked good. The low idling started immediately after the oil change and filter change out so I was hoping it was something simple. The car is also making a louder swooshing noise in boost. All the vacuum hoses that I could see looked connected? Any other suggestions or should I go get a vacuum leak test next? Link to comment Share on other sites More sharing options...
No DRFT Posted June 22, 2012 Share Posted June 22, 2012 Test it I have no control over drippie. Link to comment Share on other sites More sharing options...
SCASEYS Posted June 22, 2012 Share Posted June 22, 2012 c'mon where is BMX to tell him to do a compression test? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
MasAyinde Posted June 22, 2012 Share Posted June 22, 2012 do this and post results: http://legacygt.com/forums/showthread.php/crazy-easy-vacuum-boost-leak-tool-187968.html Link to comment Share on other sites More sharing options...
chazb22 Posted July 12, 2012 Share Posted July 12, 2012 I had the same issue...changed spark plugs and problem solved..ngk iridium one step colder Link to comment Share on other sites More sharing options...
