ColoradoR1 Posted May 24, 2012 Share Posted May 24, 2012 Long story short...driver-side door handle doesn't work from the outside (broken handle...happened a couple of months ago)...now have a dead battery. So, keyfob won't work and the key entry on the driver-side won't work. Is there an easy way to pop the hood so I can charge the battery...or is there an easy way to get in the passenger-side door since we have frameless windows (i.e. coat hanger). Did a search with no avail. Link to comment Share on other sites More sharing options...
12sechatch Posted May 24, 2012 Share Posted May 24, 2012 call the police or a tow truck. They'll come by with a slim jim. If you call the non-emergency police number they'll have someone come by eventually....might take a long time though. Link to comment Share on other sites More sharing options...
car_cursed Posted May 24, 2012 Share Posted May 24, 2012 Aaa. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted May 24, 2012 Share Posted May 24, 2012 Call AAA Link to comment Share on other sites More sharing options...
TurboLag23 Posted May 24, 2012 Share Posted May 24, 2012 I got locked inside my car one time... sucked Hahahaha just foolin around; AAA's probably the way to go. Link to comment Share on other sites More sharing options...
TurboLag23 Posted May 24, 2012 Share Posted May 24, 2012 Double poooooooost; internet's laggy Link to comment Share on other sites More sharing options...
Code Posted May 24, 2012 Share Posted May 24, 2012 Bfh "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
robitrice Posted May 24, 2012 Share Posted May 24, 2012 ive broken into my car may times its easy with the frame less windows as long as you are careful. if you can wedge the window a 1/4 - 1/2inch and find something long enough to unlock the door you are good Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted May 25, 2012 Share Posted May 25, 2012 My Options: 1. Google/Yellow Pages - Locksmith - probably cost you 40 bucks 2. Big Rock - probably cost you more than 40 bucks to replace broken window 3. Coat hanger and 10 minutes of trial and error - free + cost of coat hanger Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted May 25, 2012 Share Posted May 25, 2012 I got locked inside my car one time... sucked Hahahaha just foolin around; AAA's probably the way to go. Family Guy ref...... Link to comment Share on other sites More sharing options...
JPU1 Posted May 25, 2012 Share Posted May 25, 2012 locked myself out once at work. 1.Went back in 2.Borrowed Sphygmomanometer (Blood Pressure Cuff) 3.Borrowed wire hanger 4.Returned to car 5.Slip cuff into window 6.Inflate 7.Use Hanger to unlock door Also did this another time at a strip mall. Went and bought a slim curtain rod in the dollar store, luckily I left my moonroof vented. It was too easy, took like 10 seconds. (I don't leave the moonroof vented anymore) Link to comment Share on other sites More sharing options...
rweezy Posted May 25, 2012 Share Posted May 25, 2012 I locked my keys in mine once. I just got a coat hanger and put it through some 1/4" vinyl tubing to protect the window seal. Put the vinyl tubing between the glass and seal, that way it allows you a pathway to slide your coat hanger in and out to grab the handle. Worked pretty well for me probably took about ten minutes of trial and error. Link to comment Share on other sites More sharing options...
pillboy Posted May 25, 2012 Share Posted May 25, 2012 Well if the battery is dead, pressing the unlock button with something stuck through the window or sunroof will not unlock the doors. I have no idea how I would flip the manual lock button on my 2005 with a coat hanger or curtain rod. I do like the blood pressure cuff idea...very clever. It is still ugly. Link to comment Share on other sites More sharing options...
JPU1 Posted May 26, 2012 Share Posted May 26, 2012 The mechanism is unlocked by pressing it not pulling it... Link to comment Share on other sites More sharing options...
pillboy Posted May 26, 2012 Share Posted May 26, 2012 I think I misunderstood you. I presume you slipped the blood pressure cuff between the window and the door. I originally thought you meant between the window and the weatherstripping (attached to the body) at the top or trailing edge of the window by the B pillar. It is still ugly. Link to comment Share on other sites More sharing options...
ColdBore Posted May 26, 2012 Share Posted May 26, 2012 Sphygmomanometer wow, thats intense Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted May 28, 2012 Share Posted May 28, 2012 So... Are you still locked out? Link to comment Share on other sites More sharing options...
cypher0117 Posted May 29, 2012 Share Posted May 29, 2012 The mechanism is unlocked by pressing it not pulling it... mines unlocked by pulling the lever back. anyways, doing this with a dead battery will do nothing. You'll need to find something stiffer than a coat hanger to be able to turn the locking mechanism. AAA has something that works great (I've seen it once). Might be easier to put a hooked end on a long metal rod you can get for $2 at Menards and pop the hood with it by slipping it in through the window Link to comment Share on other sites More sharing options...
c-lo Posted May 29, 2012 Share Posted May 29, 2012 locked myself out once at work. 1.Went back in 2.Borrowed Sphygmomanometer (Blood Pressure Cuff) 3.Borrowed wire hanger 4.Returned to car 5.Slip cuff into window 6.Inflate 7.Use Hanger to unlock door Also did this another time at a strip mall. Went and bought a slim curtain rod in the dollar store, luckily I left my moonroof vented. It was too easy, took like 10 seconds. (I don't leave the moonroof vented anymore) peeenis pump would've been more impressive:hide: 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
JPU1 Posted May 30, 2012 Share Posted May 30, 2012 mines unlocked by pulling the lever back. The LOCK mechanism pushes in to unlock, it's ass backwards if you ask me but that's the way it is. But OP did say that his handle is broken anyway. When I did this the car had a good battery, and my door handle works. So may not be so helpful for him. Link to comment Share on other sites More sharing options...
Dujo Posted May 30, 2012 Share Posted May 30, 2012 How do you usually get in the car if you don't go through the driver's door. Do you get in from the passenger side? That'd be reason enough for me to get that fixed immediately. I know that's of no use to you right now, but ... just sayin. Link to comment Share on other sites More sharing options...
