ibr_adam09 Posted November 30, 2013 Share Posted November 30, 2013 bad coil! Link to comment Share on other sites More sharing options...
idiot4hire Posted November 30, 2013 Share Posted November 30, 2013 I know nothing about tuning but I had similar symptoms last winter when I was over boosting and hitting the fuel cut Link to comment Share on other sites More sharing options...
ehsnils Posted November 30, 2013 Share Posted November 30, 2013 To me it looks like you have a power supply problem (freezing while logging). Check all fuses including main fuse and fusible links and grounding points involved with the ECU. Also check the ignition lock. Link to comment Share on other sites More sharing options...
ehsnils Posted November 30, 2013 Share Posted November 30, 2013 Add to it grounding of the ECU under the dashboard. Link to comment Share on other sites More sharing options...
ehsnils Posted December 2, 2013 Share Posted December 2, 2013 I was specifically asking for the ECU grounding, which is wired under the dashboard, so you need to poke your head under it and leave footprints in the ceiling to check that. And be aware that you may have ground sometimes and sometimes not which is why the problems are intermittent. It can of course be the power too. Did you check the ignition lock? It's known to sometimes cause problems like that. Link to comment Share on other sites More sharing options...
ehsnils Posted December 2, 2013 Share Posted December 2, 2013 Looking a bit on the wiring diagram I would say that jumping a wire between any fuse marked "B" in the cabin to fuse 12 should circumvent the ignition lock. But check Fuse 12 to make sure it's OK. You may need to make some kind of "vampire" fuse using a soldering iron. Put a switch on the wire so you can cut the power if necessary. Look here too: http://legacygt.com/forums/showpost.php?p=4487789&postcount=359 Page 5148 for '05. Link to comment Share on other sites More sharing options...
heiche Posted December 2, 2013 Share Posted December 2, 2013 There was a recent thread where somebody's aftermarket intake hose was collapsing closed under heavy open throttle, and it would act like a serious fuel cut. Possible? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
ehsnils Posted December 2, 2013 Share Posted December 2, 2013 There was a recent thread where somebody's aftermarket intake hose was collapsing closed under heavy open throttle, and it would act like a serious fuel cut. Possible? It wouldn't explain why the logging freezes, which leads me to suspect electrical demons. Link to comment Share on other sites More sharing options...
heiche Posted December 2, 2013 Share Posted December 2, 2013 It wouldn't explain why the logging freezes, which leads me to suspect electrical demons. I also had that thought, but I took a chance with the "collapsing intake" suggestion because having logs freeze under WOT is such a common unrelated issue itself (even happened to me before I added the capacitor across k-line and ground!). Anyway, I tend to always agree with your assessments ehsnils Just thought I'd throw this one in there too. BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
heiche Posted December 3, 2013 Share Posted December 3, 2013 In another recent post from another member, under load the engine would stutter and logging would cut out. Turned out to be a cracked spark plug - perhaps it was arcing and wreaking electrical havoc? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
Erickslgt Posted December 3, 2013 Share Posted December 3, 2013 Do your homework on part throttle boost. Link to comment Share on other sites More sharing options...
heiche Posted December 5, 2013 Share Posted December 5, 2013 Nice! That's the sort of problem you actually hope for BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
ehsnils Posted December 5, 2013 Share Posted December 5, 2013 Nice with progress! Link to comment Share on other sites More sharing options...
