normality78 Posted September 7, 2011 Share Posted September 7, 2011 Anyone here having stock spring on Bilstein shock? Would like to know how is the ride result Link to comment Share on other sites More sharing options...
Malt Beverage Posted October 5, 2011 Share Posted October 5, 2011 I tried the stockers on my Bilstein setup. The rears fit fine, but the stock springs jack up the front as they seem to be longer than the strut requires. The springs also don't really compliment the HD's that well. Ride quality is improved, but not that much. if you put the money into the struts, get some good springs as well. I ordered a set of Pink springs right after installing with the stock springs. Link to comment Share on other sites More sharing options...
normality78 Posted October 6, 2011 Author Share Posted October 6, 2011 Malt, u may want to think twice on pink spring. I was on Pink spring / Bilstein HD. Not nice at all. Literally hopping on every uneven road. That is why i created this thread tot of replacing the pink out but retain the shock. Now im on H&R with Bilstein HD. Feel good Link to comment Share on other sites More sharing options...
Malt Beverage Posted October 6, 2011 Share Posted October 6, 2011 I'm very happy with the ride quality on the pinks. Put about 200 miles on them since installing them yesterday and most of my travel was on terrible New England roads. The ride actually feels less harsh now than with the stocks. Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 7, 2011 Share Posted October 7, 2011 Malt, u may want to think twice on pink spring. I was on Pink spring / Bilstein HD. Not nice at all. Literally hopping on every uneven road. That is why i created this thread tot of replacing the pink out but retain the shock. Now im on H&R with Bilstein HD. Feel good How do your LCA bushings look? Those could contribute to a loose, hoppy feeling front end. Link to comment Share on other sites More sharing options...
normality78 Posted October 7, 2011 Author Share Posted October 7, 2011 LCA = Lower camber arm? Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 7, 2011 Share Posted October 7, 2011 LCA bushings means the rear bushings on the front control arms (the big round ones). Something must have been odd in your car. Mine with pinks is a LITTLE bouncy, but only when I hit the rear bumpstops. It's firm, but much less harsh than the springs I had before. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Malt Beverage Posted October 7, 2011 Share Posted October 7, 2011 My front LCA bushings were smoked, literally falling apart (at around 110k miles). I replaced them both (front and rear bushings) with the AVO polyurethane bushings when I did my strut install. These probably subtract a bit on ride comfort, but really firm up the front end. Even new OEM bushings will really tighten things up. They also only cost about $10. Link to comment Share on other sites More sharing options...
Zac88 Posted November 20, 2011 Share Posted November 20, 2011 so stock springs wont work on the Bilstein HD's? Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 20, 2011 Share Posted November 20, 2011 They work.. just your front end will be sitting up higher than it did stock. Link to comment Share on other sites More sharing options...
Zac88 Posted November 22, 2011 Share Posted November 22, 2011 And that's because of what the spec B top hats? Link to comment Share on other sites More sharing options...
Malt Beverage Posted November 23, 2011 Share Posted November 23, 2011 From my observations, I tired the stock springs with the Bilsteins, the Bilstein assembly (strut+mount) has less space between upper and lower spring seats and requires a shorter spring. Link to comment Share on other sites More sharing options...
