Grimmspeed EBCS with stock bleed type routing
Hi everyone,
Long story short, I used to have a stage 3 tune with the grimmspeed EBCS but because of smog, I had to revert back to the VF40 stock map.
i can't find my stock boost solenoid so I need to hook up the EBCS as a 2-port bleed type but I am confused as to how.
I am trying to follow the instructions below but i'm still having issues connecting the lines.
https://www.grimmspeed.com/content/install_guides/boost_control_solenoid_online_version.pdf
so question:
port 2 connects to the wastegate?
- should I use the stock T-fitting, 1 side connecting to the internal waste gate and the other including the pill connects to the turbo inlet?
port 3 leave open
port 1 connect to intake snorkel.
or do I have this all messed up?
thanks
I don't know the answer to your question. I installed a Perrin EBCS a few days ago and am not confident I did it right. I think I might have blown my engine tonight. Actually I think I did the solenoid right but blew the engine by overboosting on a base map.
Sorry for thread hijacking. Just bummed and I was just struggling with a ebcs a few days ago so I can relate.
i'm sorry to hear that, any news on the motor?
I'd call them as they've left out the figure 2 in that manual, the one that shows you how to hook it up in bleed mode.
thanks dga, I'll see if i can give them a call later then. Until then hopefully someone knows how to hook this up in 2-port mode
Thanks everyone,
also I reached out to Grimmspeed and got a response from them:
Port 1 - to the T fitting (t fitting between compressor housing and wastegate)
Port 2 - Turbo inlet
Port 3 - Capped
which seems to be what the Mazdaspeed 6 manual suggests as well.
