Dual piston brake compression...
mtenhoven
I'm getting ready to install new pads on my GTs front brakes.
One question though. How should the dual pistons be compressed using the c-clamp/board technique? Individually or at the same time. It seems that if both pistons were attempted at the same time the pressure from the c-clamp would be inbetween the individual pistons. Could one or both of the pistons be compressed at an angle; thereby screwing up the caliper operation later?
Thanks!
Remember to open the brake fluid reservoir to allow the system to breath and put some cloth around it so anything that overflows is caught. If you do not open the reservoir it will leak through the seals of the master cylinder.
I keed I keeed
