dynamic_3.6 Posted August 7, 2011 Share Posted August 7, 2011 So I'm installing my new RCE springs and I've gotten the front driver side strut off the car but apparently I need a Subaru special tool to disassemble it. The manual says I need ST 20399AG000 STRUT MOUNT SOCKET....does anyone know where to get one of these? Or is there a workaround for it? I tried everything I can think of but the nut is triangular and I'm afraid of rounding it. Please help! Link to comment Share on other sites More sharing options...
sheppo9 Posted August 7, 2011 Share Posted August 7, 2011 The 'triangle' nut is just Subaru's version of a lock nut. Either use a rattle gun to undo it, or use an allen key in the strut itself and a spanner to undo the nut. You'll probably need spring compressors too. Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 7, 2011 Share Posted August 7, 2011 The 'triangle' nut is just Subaru's version of a lock nut. Either use a rattle gun to undo it, or use an allen key in the strut itself and a spanner to undo the nut. You'll probably need spring compressors too. What the heck is a "rattle gun"? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mwiener2 Posted August 7, 2011 Share Posted August 7, 2011 it's an impact gun with an aerosol can attached as a propellant. Duh. Best thing to do is go to the store and buy a deep socket and then weld a handle to it. Then use it and an allen key. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BAC5.2 Posted August 8, 2011 Share Posted August 8, 2011 it's an impact gun with an aerosol can attached as a propellant. Duh. Best thing to do is go to the store and buy a deep socket and then weld a handle to it. Then use it and an allen key. Or grind flats into the top, and use a wrench. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
bmx045 Posted August 9, 2011 Share Posted August 9, 2011 A good enough impact gun will zip those nuts off without any need for an allen key. Just make sure you compressed the spring first ! the top hat may fly off and strike your domepiece with great success! Link to comment Share on other sites More sharing options...
mwiener2 Posted August 10, 2011 Share Posted August 10, 2011 ^^ and you may spin the shaft and unscrew internals in the shock. Lots of people do, but you're not supposed to use an impact gun on the struts. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bmx045 Posted August 10, 2011 Share Posted August 10, 2011 with a good enough impact gun the shaft wont feel a damn thing, hell you don't even need to hold the shaft, the gun will zip it off before the shaft has time to spin. and yes, that's what she said. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 11, 2011 Share Posted August 11, 2011 you just keep telling yourself that My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
sheppo9 Posted August 11, 2011 Share Posted August 11, 2011 I'll tell myself that too then... I've always used an impact wrench/rattle gun to get the nuts off. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 12, 2011 Share Posted August 12, 2011 "Always" between the two of you being what, 3 or 4 sets of shocks? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bmx045 Posted August 12, 2011 Share Posted August 12, 2011 Ive done this with a few sets. No problemo. Mr snap-on works well Link to comment Share on other sites More sharing options...
AZP Installs Posted August 12, 2011 Share Posted August 12, 2011 Gear wrench sells a kit that has open socket sets so you can fit in an allen key to hold the strut. Dont know the cost off hand but theyve helped us a lot in the past. Link to comment Share on other sites More sharing options...
