hlewis12 Posted August 21, 2008 Share Posted August 21, 2008 What can I do to fix this? Its like the bushings are worn out and the car makes a popping noise when you put it in reverse and step on the gas. Can you just replace the bushings or does more need to be done? Its on a 2000 Legacy GT. Thanks for any help. http://i48.photobucket.com/albums/f234/jessbishop/2000LegacyGT008.jpg http://i48.photobucket.com/albums/f234/jessbishop/2000LegacyGT009.jpg Link to comment Share on other sites More sharing options...
AWDMIG Posted August 21, 2008 Share Posted August 21, 2008 Just replace the bushings I am not sure what the fit is but maybe some group N's will be better choice and last longer Link to comment Share on other sites More sharing options...
hlewis12 Posted August 23, 2008 Author Share Posted August 23, 2008 What are these bushings called and how hard are they to replace Link to comment Share on other sites More sharing options...
hlewis12 Posted August 27, 2008 Author Share Posted August 27, 2008 the noise seems to be getting worse by the day Link to comment Share on other sites More sharing options...
Underdog Posted August 27, 2008 Share Posted August 27, 2008 Not sure what the name is but I believe the connect the differential to the sub-frame. I would imagine installation is difficult and would require several hours and a hydraulic press. The Crimson Dynamo Link to comment Share on other sites More sharing options...
