patgman21 Posted May 17, 2010 Share Posted May 17, 2010 just got an 05lgt and of course as im driving her home the dreaded cel comes on...had it read as a cylinder 4 misfire...drove home from the store and it turned off itself...long story short, the cel has come on and turned off about 4 times...could this narrow it down to a certain issue (ie: coil packs, plugs, etc)...or shall i do the normal approach as to swapping the plugs first? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2010 Share Posted May 18, 2010 Take it to a auto parts store and have them read the code (s). They do it for free. Or pull the negative battery cable for a few minutes to reset the ECU. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
patgman21 Posted May 18, 2010 Author Share Posted May 18, 2010 p0304...cylinder 4 misfire Link to comment Share on other sites More sharing options...
lee07 Posted May 18, 2010 Share Posted May 18, 2010 Could be many things. I would first change the plugs since you just bought it. If plugs weren't it switch the coil packs around be sure to check the coil too for cracks or anything. Also check the wire for the coil. If not these could be an injector Or worse yet just like me a burnt intake valve. Link to comment Share on other sites More sharing options...
BruceBruce Posted May 18, 2010 Share Posted May 18, 2010 my p0303 was a the inj. I pulled the plug first and it looked clean so i put it back. than switched the inj to the #2 cylinder and thats where the misfire went. Just so you know the number 4 cyl is driver side rear looking at the engine from the front. Link to comment Share on other sites More sharing options...
patgman21 Posted May 19, 2010 Author Share Posted May 19, 2010 thanks guys..i will get in there today and switch the injector to see if the code follows it...seems to be the injector is bad with most people who have this misfire code Link to comment Share on other sites More sharing options...
