Boostin1657615274 Posted April 12, 2011 Share Posted April 12, 2011 I am trying to justify which bushings are going to be worthwhile to me. Here is my situation: I think the LCA bushings are starting to go out at 70k, so my idea started with the Anti-Lift Kit. I started looking through all the bushings Whiteline offers and can't make an educated decision on which ones I need. My setup (only listing bushings and suspension components): Upgraded Bushings so far (upgraded during clutch job): -Group N Transmission mounts -Group N Crossmember bushings -Perrin Front Shift Bushing -Group N Rear Shifter Bushing Suspension: -BC BR Coilovers with ~2"-2.5" drop I want to upgrade everything suspension here shortly, so will be doing sway bars, endlinks, RSB mounts, etc. (Probably Hotchkis Sways, Rallitek HD Endlinks & AVO RSB Mounts). But, I also dont want to spend any money unnecessarily. So...which bushings of these listed should I get for a solid setup? -Anti-Lift Kit -Differential Mount Bushings -Front Inner Control Arm Bushings (heard to do these at same time as ALK since the LCA is out anyways) -Rear Differential Bushings (any different from Diff Bushings listed above?) -Roll-Center & Bump-Steer Kit -Steering Rack Bushing Kit -Rear Camber Adjustment Kit On the search for a new DD... Link to comment Share on other sites More sharing options...
xero287 Posted April 12, 2011 Share Posted April 12, 2011 Alk. Link to comment Share on other sites More sharing options...
berkshire40 Posted April 13, 2011 Share Posted April 13, 2011 I would do LCA bushings and RCK Currently I only have the LCA kit because I am not dropped as much Mod list & photos _ Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted April 13, 2011 Author Share Posted April 13, 2011 I want to clarify - I realize only few of these will actually affect handling, but I am more interested in which of these bushings are worth buying/installing for the feel/benefit? On the search for a new DD... Link to comment Share on other sites More sharing options...
SBT Posted April 13, 2011 Share Posted April 13, 2011 Do the front and rear LCA bushings (I prefer AVO's) and, since you're dropping it so much, definitely do the WL RCK - that's a must in my mind, to get rid of the bump-induced steer. Then do the other bushings as you have time, resources. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
