csbrown28 Posted December 16, 2011 Share Posted December 16, 2011 I know it's not a replacement for a good ECU program, but does anyone have any experience with this? https://market.android.com/details?id=org.prowl.torque&feature=apps_topselling_paid#?t=W251bGwsMSwxLG51bGwsIm9yZy5wcm93bC50b3JxdWUiXQ.. To make it work says you need OBD II Bluetooth adapter. Can we use these with the 06? Link to comment Share on other sites More sharing options...
Subfan Posted December 17, 2011 Share Posted December 17, 2011 I have it, and yes, it works on an 06. I bought it mainly because i was curious. I got the obdii reader from amazon for $8.00 and used the free version of Torque. It was worth $8.00 for sure. I don't think I will use it again other than to show people how it works, or if I end up needing it to pull a CEL code. Link to comment Share on other sites More sharing options...
csbrown28 Posted December 17, 2011 Author Share Posted December 17, 2011 I have it, and yes, it works on an 06. I bought it mainly because i was curious. I got the obdii reader from amazon for $8.00 and used the free version of Torque. It was worth $8.00 for sure. I don't think I will use it again other than to show people how it works, or if I end up needing it to pull a CEL code. Mind telling me which OBDii reader you bought? Does Torque do half of what it says? Link to comment Share on other sites More sharing options...
Subfan Posted December 17, 2011 Share Posted December 17, 2011 Mind telling me which OBDii reader you bought? Does Torque do half of what it says? [ame=http://www.amazon.com/Bluetooth-Diagnostic-Scanner-Koolertron--Check-Engine/dp/B0055AZ0A0/ref=sr_1_3?s=automotive&ie=UTF8&qid=1324144422&sr=1-3]Amazon.com: ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner PC Car Diagnostic by Koolertron--Check Engine Light: Automotive[/ame] This is the one I bought. It looks like the price has gone up since I bought mine... (You may find one cheaper on Ebay, just make sure it is the Bluetooth Elm 327) I didn't buy the full version of Torque (yet), so I can't tell you if it does all of the things it says it can do. I can tell you that the free version does what it says. It is not one of the most "Polished" apps I have run across, but seems to work good and other than a few visuals, I cant complain. I attached a screenshot to show how I set up one of the screens. Link to comment Share on other sites More sharing options...
09obpleg Posted December 18, 2011 Share Posted December 18, 2011 i have it, use the paid version, a lot nicer then the free version, gotta get it all set up to your liking tho, but has a lot of useful items in it. nice for pulling codes to. using kiwi Bluetooth adapter. app developer updates at least once a week for new items or bug fixes Link to comment Share on other sites More sharing options...
csbrown28 Posted December 19, 2011 Author Share Posted December 19, 2011 i have it, use the paid version, a lot nicer then the free version, gotta get it all set up to your liking tho, but has a lot of useful items in it. nice for pulling codes to. using kiwi Bluetooth adapter. app developer updates at least once a week for new items or bug fixes Can the Bluetooth receiver be used to connect to a PC as well for the programs (like ROM Raider) used to collect ECU data? In other words does it take the place of a Tactrix and/ or VAG cable? Link to comment Share on other sites More sharing options...
09obpleg Posted December 19, 2011 Share Posted December 19, 2011 haven't tried it, so i couldn't tell ya, i don't see why it couldn't, i'll try to play around with it on the computer and see what it does. wouldn't trust it for reprogramming tho Link to comment Share on other sites More sharing options...
csbrown28 Posted December 19, 2011 Author Share Posted December 19, 2011 haven't tried it, so i couldn't tell ya, i don't see why it couldn't, i'll try to play around with it on the computer and see what it does. wouldn't trust it for reprogramming tho Hahaha, Amen!....I just thought it would be nice to be able to log to my PC without having the cable running around my feet. Link to comment Share on other sites More sharing options...
NSFW Posted December 25, 2011 Share Posted December 25, 2011 ELM-based devices are much slower than Tactrix-style SSM logging. They're fine for display, but they won't produce useful logs for tuning purposes. Link to comment Share on other sites More sharing options...
csbrown28 Posted December 25, 2011 Author Share Posted December 25, 2011 ELM-based devices are much slower than Tactrix-style SSM logging. They're fine for display, but they won't produce useful logs for tuning purposes. That's good information, but instead of just knowing what will work and what won't work, I'm the kinda guy that asks....Why is it to slow for logging for tuning? Thanks. Link to comment Share on other sites More sharing options...
NSFW Posted December 25, 2011 Share Posted December 25, 2011 With my car, the 'slow' mode of SSM logging produces about 4-5 rows per second with a dozen parameters per row, which is just enough to see what's going on. The 'fast' mode raises that to about 15 rows per second with about 18 parameters, which is great. Newer cars (07+, if I remember right) can log even faster. With an ELM device I was seeing maybe 5 updates per second with a single parameter. It's been a while, so I don't remember the rate very clearly, but with 5 parameters selected, I could watch each of them update individually. If I were to log a pull that way, and see knock in the data log, the time delay from one parameter to the next would make it hard to figure out what the RPM and load parameters were at the time the knock occurred. One second is enough time for those parameters to change quite a bit, and they don't usually change in a linear way. It would be like starting with a regular SSM data log and removing all but one parameter from each row of data. Link to comment Share on other sites More sharing options...
csbrown28 Posted December 26, 2011 Author Share Posted December 26, 2011 With my car, the 'slow' mode of SSM logging produces about 4-5 rows per second with a dozen parameters per row, which is just enough to see what's going on. The 'fast' mode raises that to about 15 rows per second with about 18 parameters, which is great. Newer cars (07+, if I remember right) can log even faster. With an ELM device I was seeing maybe 5 updates per second with a single parameter. It's been a while, so I don't remember the rate very clearly, but with 5 parameters selected, I could watch each of them update individually. If I were to log a pull that way, and see knock in the data log, the time delay from one parameter to the next would make it hard to figure out what the RPM and load parameters were at the time the knock occurred. One second is enough time for those parameters to change quite a bit, and they don't usually change in a linear way. It would be like starting with a regular SSM data log and removing all but one parameter from each row of data. Again, good info, thx 4 the update Link to comment Share on other sites More sharing options...
csbrown28 Posted December 30, 2011 Author Share Posted December 30, 2011 Ok so I got it all set up, pretty cool.... http://i1116.photobucket.com/albums/k563/csbrown28/screenshot.jpg For the boost, and HP data, no idea what these should be, nor am I sure how accurate this info really is. All in all it's a neat toy. Link to comment Share on other sites More sharing options...
theflystyle Posted December 31, 2011 Share Posted December 31, 2011 thanks for the update. i just ordered a bluetooth adapter and just downloaded the free version of torque. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted January 1, 2012 Share Posted January 1, 2012 pay version of Torque is much much much nicer than the free version, i highly recommend buying the pay version. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 1, 2012 Share Posted January 1, 2012 Not sure if you guys are aware, but there is a thread that was created a while ago just about that android app. ----> HERE Link to comment Share on other sites More sharing options...
