05LegacyGTArmyguy Posted February 4, 2014 Share Posted February 4, 2014 Just bought the car..A/C Blows through defrost vents and outside Dash vents and will not blow through the center dash vents...I hear a noise in the dash when I turn the car off like a servo is hung up Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 That sounds like you have found the problem. This is the first time I have heard of this problem. May be check the Tech forums below, you may find help there. You can find the service manual in the Gen Chat forum. look for the thread about show me your vacation Pix'. About 10 pages in, about 2010 you'll find a link. http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216p10.html here this is easier, http://people.csail.mit.edu/ilh/vacation/ the GT's start around page 1600, in 2005. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
05LegacyGTArmyguy Posted February 4, 2014 Author Share Posted February 4, 2014 Ok thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 Let us know what you find out, we love info. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chappy5107 Posted February 4, 2014 Share Posted February 4, 2014 More than likely the electronic motor that changes the different flows is bad. I had to replace mine not to long ago. Mine wouldn't open the defroster, you can drop the glove box and press the button and look and see if the motor is actually moving or not. Link to comment Share on other sites More sharing options...
05LegacyGTArmyguy Posted February 4, 2014 Author Share Posted February 4, 2014 im thinking the same thing. I saw somewhere in the forums some kind of actuator is the culprit Link to comment Share on other sites More sharing options...
Chappy5107 Posted February 4, 2014 Share Posted February 4, 2014 Yea there are two on the passenger side the bottom one is for he passenger temp control and the upper one is for the flow divider. Quite a pain to reach but can be done with simple tools and time Link to comment Share on other sites More sharing options...
ppettit2005 Posted July 11, 2014 Share Posted July 11, 2014 I have the exact same issue, except air is coming out of all of my vents all the time plus there's that annoying whirring/clicking sound. a solution would be much appreciated. Link to comment Share on other sites More sharing options...
lingling1337 Posted July 11, 2014 Share Posted July 11, 2014 Mine blows air as if its on fan setting one when its off. So I have to turn it to ~70 before I turn it off so it doesn't keep shooting cold air. Link to comment Share on other sites More sharing options...
Jazz95 Posted July 14, 2014 Share Posted July 14, 2014 More than likely the electronic motor that changes the different flows is bad. I had to replace mine not to long ago. Mine wouldn't open the defroster, you can drop the glove box and press the button and look and see if the motor is actually moving or not. ^^^ This one. Same thing happened to me, wound up replacing the servo motor which wasn't that hard, just make sure you have a shorty Philips head screwdriver. Link to comment Share on other sites More sharing options...
nouse4aname Posted July 14, 2014 Share Posted July 14, 2014 Mine blows air as if its on fan setting one when its off. So I have to turn it to ~70 before I turn it off so it doesn't keep shooting cold air. Turn it to recirc before you turn it off to kill the external air flow. Link to comment Share on other sites More sharing options...
