robburns201 Posted September 11, 2017 Share Posted September 11, 2017 I was wondering if I should be using the Cobb stg 2 sf tune with the following mods...k+n stock box,perrin intercooler,gs catless up,invidia catted dp,Hks catback.... Any thoughts is appreciated.... Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
MrMileHighGuy Posted September 12, 2017 Share Posted September 12, 2017 Yes stage 2. I'm pretty sure going beyond that is after upgrading turbo, fuel pump, injectors. I'm sure others will chime in shortly. Link to comment Share on other sites More sharing options...
gkinslow Posted September 12, 2017 Share Posted September 12, 2017 Protune With that many mods you need a protune to get the most out of them and have a "safe" tune. The OTS maps are designed for Cobb products, each car is different even if the mods are the same. Protune will be tailored to your specific setup. That being said, I think you are using the correct OTS map for your setup. If you have doubts you can always email Cobb. They've always gotten back to me quickly. Link to comment Share on other sites More sharing options...
Dishwasher Posted September 12, 2017 Share Posted September 12, 2017 Does the Cobb OTS Stage 2 map work with an intercooler? I'm not sure it does. I'd definitely recommend a pro tune either way. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
gkinslow Posted September 12, 2017 Share Posted September 12, 2017 Intercooler is one of those highly debated issues. "You can install without a tune, you just won't get the full benefit" gets thrown around a lot. At least his TMIC is comparable in size to the stock TMIC and not the much larger GS or PW units. Etune from Cryo or TA would be easy. Link to comment Share on other sites More sharing options...
vnhqle Posted September 12, 2017 Share Posted September 12, 2017 I'd recommend a specific tune for every car. Etune should be sufficient; however, protune would be best. The Cobb ots should be a temporary solution. To answer your question, the stage 2 should be the correct one. Link to comment Share on other sites More sharing options...
relative4 Posted September 13, 2017 Share Posted September 13, 2017 Certainly a pro tune is a good idea, but the OTS stage 2 is OK for that setup. However, you may want to reconsider the K&N. Oiled filters are problematic for MAF vehicles in general and especially so for these. Google for details. Also, the Perrin IC is pointless with stock turbo and fueling. Link to comment Share on other sites More sharing options...
robburns201 Posted September 14, 2017 Author Share Posted September 14, 2017 Why is the Perrin ic pointless? Should I go back to stock? Sent from my 0PJA2 using Tapatalk Link to comment Share on other sites More sharing options...
John J Posted September 14, 2017 Share Posted September 14, 2017 When I bought my GT wagon the previous owner ran with Headers, uppipe, downpipe, Perrin intercooler, and Cobb OTS Stage 2 tune. It had 160k miles on it and it ran fine, but after a pro tune it runs finer. Definitely worth what it cost. Link to comment Share on other sites More sharing options...
sanchitosonria Posted September 15, 2017 Share Posted September 15, 2017 Certainly a pro tune is a good idea, but the OTS stage 2 is OK for that setup. However, you may want to reconsider the K&N. Oiled filters are problematic for MAF vehicles in general and especially so for these. Google for details. Also, the Perrin IC is pointless with stock turbo and fueling. Been using K&N filters for many years in all my cars and I have never had an issue. Issue comes from over oiling during the cleaning process. Link to comment Share on other sites More sharing options...
