JDM Aero spats install???
Totaled04Rex
So I got a set of these from Japan from a member here. He assured me they are for the sedan, but when I test fit them not all the holes line up. Also the inside part in the front seams to be a little longer than where it mounts to. Lastly the clips won't push in and lock on certain holes because it feels like the spat makes it too tall to properly click closed. The fronts have 2 mounting points on the bottom that don't like up to anything so I'm guessing use screws on those?
Does anyone have a walk though or some insight into how to make these work?
I tried searching and could only find GB and FS threads no install ones.
Thanks in advance really wanting to get these mounted!
http://img.tapatalk.com/d/13/06/19/egubeny2.jpg
This clip won't seat far enough to be able to pop down the locking part
http://img.tapatalk.com/d/13/06/19/udybe8ud.jpg
These two mounting holes which were clearly used to mount it on the previous JDM car don't line up with anything. Does anyone know if I put two screws into the bottom of the side skirt if that will mess up anything under the skirt, like wires or important stuffs?
The rears look like they will be easier and line up.
I'd rather not use double sided sticky tape because if I ever sell the car I want to be able to strip the parts off and sell them. Plus that's a Honda rice body kit trick IMO lol
Any tips or pics of your install would be awesome.
Thanks in advance and happy boosting!
Majority of forum members just used self tapping screws and mounted them to the rocker panels underneath directly.
The locking clips gave me s hard time but I eventually popped them all in with a good bit of effort.
Hope this helps
3m double sided outdoor tape, and the stock clips and they are on!!! Might add some screws in the bottom later, but as of now they appear to be very solid. At least 2 clips on each one and tape all along the edge where the factory tape was and it should be good!
Pics to come shortly
  • 1 month later...
;) sorry forgot all about this lol
http://img.tapatalk.com/d/13/08/01/e9a3y8y9.jpg
The rears don't sit flush to the bumper at the back for about 3-4". I think with some screws instead of the factory mounting points I could get them flush but it hasn't bothered me enough to fix it when it's 100+ outside every day ;)
How did you mount them?
Installed mine last night. They are flush, it rained and now I have to reset the rears because the water caused the 3m adhesive to let go. I'll post some pics tonight.
I used a rubber mallet for the pop clip in the first pic and 3M tape for the rest. 3M has an adhesive remover when and if the time calls for removal.
Haven't posted pics on the site in a while......frustration got the best of me earlier today. When I get a moment sometime during the early morning hours when I get home from work I'll post them up!:icon_mrgr
This is the best I can do. These are the install instructions in Japanese ( I assume) for the rears:
http://i238.photobucket.com/albums/ff234/evak81/Spatinstall2_zps7949273c.jpg
  • 1 year later...
