xt2005bonbon Posted September 21, 2012 Share Posted September 21, 2012 Let us assume stock set up here. We are supposed to hit a max boost of 13.5 psi. My first question is: are we supposed to be able to hit max boost at every single gear (5MT in my case)? I did a quick test last night where I hit max boost (actually 13.6) in either first or second (could not have my eyes on both the gauge and the road at the same time). But in 3rd, I just hit 12.9 I think, though I did not go all the way to redline (scared of it), and obviously began to go too fast on public road. It just seems that in 3rd, it's not as easy to hit max boost. Second question: in 3rd gear around what rpm would you hit max boost at WOT? Third question: if your engine knocks, would the ECU let you achieve max boost? Link to comment Share on other sites More sharing options...
ripemeat Posted September 21, 2012 Share Posted September 21, 2012 1. No, there's a table in the 2005 gt rom that uses a compensation for 1st gear boost targets. 2. post a log of your 3rd gear pull to confirm. 3. if the IAM drops to .35 or below you'll only be able to run wastegate boost. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted September 21, 2012 Share Posted September 21, 2012 With the 5mt third gear is the one you do a hp or tuning pull from if you cant hit "max boost" in third then you are having some issues. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 22, 2012 Author Share Posted September 22, 2012 Thanks for the insights so far. I need to get the basic equipment to start logging. Car runs great I think but you never know.. Waiting for more discussion on this topic. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 22, 2012 Author Share Posted September 22, 2012 Update: went and did a couple of 3rd gear pulls using my Torque android app to monitor boost. Outside temp was 57F with about 85% humidity at sea level. First time: reached 13.1 psi Second time: reached 13.9 psi subsequent pulls: max reached was 12.9 psi Note that I don't have a turbo heatshield. Don't know if this can affect the results. Note also that I did NOT do any pull prior to the 3rd gear pulls. Stock tune with a K&N panel filter and Perrin LCP. I think I'll ditch the panel filter soon. Link to comment Share on other sites More sharing options...
copenhagen6123 Posted September 23, 2012 Share Posted September 23, 2012 Well you really wont know what is going on until you log some data. Link to comment Share on other sites More sharing options...
